94 Formula roller For Sale
Torch Red paint/Charcoal int current 8.50 certified weight with Pontiac IAII 505/CV-1s & TH350 3220lbs, MT ET Street Drag Radials 315/60 and 26” MT Sportsman up front. All is new in this car never run. Must see to believe how nice and well done. No cheese anywhere in this car.
Chassis BMR all Cromemoly when available Turbo K member Adjustable upper and lower A arms BMR/Flaming River manual rack Sub-frame connectors Extreme torque arm Lower control arms Pan hard A/C delete plate Wolf Anti-roll Cage 8.50 guaranty re-certification Mini Tub kit Rear coil spring adjusters Strange coil overs front & rear Aerospace disc front & rear Wildwood master Moser 9” housing Strange center section, spool and 33 spline axles & 3.90 gears Turbo Action sifter 3 speed w/CO2 system Electronics Headlights, tail/driving lights & power windows work Race Pak UDX data logger dash Line Lock Biondo Mega 85 box MSD Digital 7 (7530t) & matching coil 16 volt alt and battery BeCool fans/shroud & Northern rad VFN 5” cowl hood VFN glass dash Mid plate & front motor plate for Pontiac oval 4” dual, x pipe, SpinTech and 4” tails out the back System 1 oil filter system Aluminum fuel cell Mega 300 pump & filter #10 line for both feed and return Kirby race seats Custom drive shaft 1350’s for TH350/glide She is a bit dusty sitting in the garage for the past few years but will clean up very nicely $22,500 sorry no trades. It would cost you $45k+ to build one of these and a year plus wait. Text me at 727 three 1 nine 39 zero zero |
There are many pics on my board showing the build, use the link in my sig. If you are not a member just let me know and I can help you if needed.
bump
ttt
bttt
still available
Yes it is still for sale, I really want this to go to someone putting a real Pontiac in it and not a ho hum chebby.
Curious, is that Bailey's old car?
No, this car I had built from the ground up.
still available
This is a steal compared to building one of these.
still available
TTT
Still for sale
Someone buy this so that I can get my old (Troy's) 69 GP back.
ttt
anyone know where Alex's car ended up? i see the motor is on py with new owner
The car sold to a buyer in the Orlando area. I heard his plan was for a nitrous small block.
| All times are GMT -4. The time now is 01:29 PM. |
