Splatter paint cover
I used Dupli color splatter paint in the trunk of the 69 GTO to freshen it up. Should I use a Dupli color clear to cover it with, or is any brand ok. Should it be a satin clear or other?
Thanks. |
I used the dupli clear on the GTOs and they look fine.
Post some picts if you guys don't mind.
I need to this as well soon. |
The factory didn't clear them so its personal preference. I would use satin so it looks more factory but thats just me...
I've used it before with good results - did not clear it afterwards however. I always give the trunk a black base coat before using the spatter paint - comes out nicer.
Do you use flat, semi, or gloss? Thanks Joe |
The base was a black primer, don't remember if there was a gloss option on the spatter.
I'm on vacation right now in FL, but will try and post a few pics on 1 August when I get back. I haven't put the clear on yet, I'll get pics of before and after and post them.
| All times are GMT -4. The time now is 02:03 PM. |
