Rompin Redskin 63 Catalina
Selling my 63 Pontiac Rompin Redskin. Fresh 513 cu.in IA block with Crower billet crank and AllPontiac tiger heads. All the good stuff.
I will be at Norwalk for the Tri power Nationals. $52000 Joe Zajac 414-687-6534 |
Rompin Redskin Information
Rompin Redskin
1963 Pontiac Catalina. Engine: 513 cu. In. Indian Adventures iron block 4.320” bore Crower billet crankshaft/center counterweights 4.375” stroke Titan oil pump Billet Fabrication 8 qt. oil pan Canton accusump GRP 6.800 aluminum rods Diamond pistons 55mm roller cam .904 Crower bushing lifters Manton pushrods Milodon gear cam drive CSR water pump Griffin alum radiator Spal electric fan Moroso vacuum pump Dual 16 volt batteries with charger. MSD crank trigger Mallory Hyfire 7 Pro CD ignition Racepak V-300 data recorder. Tiger heads with Titanium valves and copper beryllium seats Jesel rocker arms Wentzler gutsram aluminum intake Dual 800 cfm Edelbrock carbs. Magnafuel Prostar fuel pump and 4 port regulator. GF2000 5 speed clutchless transmission Browell aluminum bellhousing Strange 3.5” chrome moly driveshaft Boninfante 10” clutch assy. Strange Engineering 9” Ultra case with 40 spline gun drilled axles, 5.14 pro gears Four link with anti-roll bar Bogart aluminum wheels w/ 33x 10.5 x15 MT slicks Strange 4 piston brakes front and rear Strange double adjustable shocks front and rear Body Factory aluminum front fenders, inner fenders, front tray, front bumper Carbon fiber hood, grill, and deck lid. lexan marguard windows Chromoly cage 12 point Weight w/o driver 3450 lbs. Contact info: Joe Zajac 414-687-6534 [email protected] So fresh and so clean. |
Sold
| All times are GMT -4. The time now is 11:26 AM. |
