rear window reveal clip for 66 Lemans
I bought the front and rear window clip for my Lemans and it has 8 large clips and the rest are small. Do the large clips go along to top on the roof line and the small every were else. I had to replace the filler panel and rebuild the sail panels so I never got to see the original ones. Also do the clip fit to the bottom of the filler panel. A picture of the clips installed would be help full. Thanks for the help
IIRC The taller rear reveal trim clips rest aprox 5/16 off the glass ledge are all of your pins missing?
if so no worries as they have shouldered screws now just for this task. There are 4 Top & Bottom and 3 L & R. The beauty of the screw is you can adjust for any inconsistencies. I would use one of the side trim pieces to get a better visual on proper depth/setting needed. I'll see if I can can better specs off the '66 at the shop ASAP. |
| All times are GMT -4. The time now is 11:54 PM. |
