-   -   455 score (https://forums.maxperformanceinc.com/forums/showthread.php?t=807326)
64speed 07-12-2017 10:31 PM
455 score
I started a new thread because the news is so good I had to make sure you guys read it. I still have the 455 that has the mismatched mains but.......drumroll please........the other complete 455 I went to look at wasn't stuck after all. The guy just didn't know the old PB blaster and transmission fluid trick so now I have a 73 with its main caps that's not stuck for 150 bucks. I feel like having a beer and I rarely drink. Finally a solid foundation to build on and with very little money. So here's to us and those like us. I even got 73 4X heads that have been ported but I think the combustion chamber is still too big. They are numbers matching to the block. I traded the crank and pistons and rods for some other parts I needed because I plan to buy a scat kit anyway. So in short happy day to me. I will just save the other block for emergency. Thanks for those that listened and supported a private messaged me but in the words of Gerald Ford my long national nightmare is over.
hurryinhoosier62 07-12-2017 10:50 PM
Good deal! Get that sucker to you the machine shop and get it magnafluxed.
STEELCITYFIREBIRD 07-12-2017 11:00 PM
You have been a busy boy, buying main cap sets, trading parts...and posting more new threads, good luck!
Tom Vaught 07-12-2017 11:19 PM
Glad the other engine will work for you.
My biggest fear was not your ability to buy the main caps but the machine shop having the capability to install 5 main caps correctly without wasting more of your money.
Tom V.
64speed 07-12-2017 11:30 PM
Well I'm gonna keep that motor and its main caps around in case of emergency but I am going to have this block vatted magnafluxed and just generally cleaned up but that's all I've got the money for right now. I will keep you posted as the build progresses. Gonna buy the scat kit at tax time and Edelbrock rpm cnc ported heads asap. Machinist says the valvesprings on the edelbrock suck so unless I am running the summit cam then upgrade them so I guess I will order a comp cams kit. Who makes the stump puller I always see people talking about? Engine has to be docile enough to run power brakes and ac, but I want to push it to the edges of streets le power with non sti
64speed 07-12-2017 11:35 PM
[QUOTE=64speed;5761351]I started a new thread because the news is so good I had to make sure you guys read it. I still have the 455 that has the mismatched mains but.......drumroll please........the other complete 455 I went to look at wasn't stuck after all. The guy just didn't know the old PB blaster and transmission fluid trick so now I have a 73 with its main caps that's not stuck for 150 bucks. I feel like having a beer and I rarely drink. Finally a solid foundation to build on and with very little money. So here's to us and those like us. I even got 73 4X heads that have been ported but I think the combustion chamber is still too big. They are numbers matching to the block. I traded the crank and pistons and rods for some other parts I needed because I plan to buy a scat kit anyway. So in short happy day to me. I will just save the other block for emergency. Thanks for those that listened and supported a private messaged me but in the words of Gerald Ford my long national nightmare is over.
P.s. Are these 4X heads worth anything they have screw in studs.
MDGOAT69 07-13-2017 01:56 AM
Sounds like a good deal!
gtofreek 07-13-2017 01:59 AM
Glad you found a good engine to build! That's better than trying to get main caps fitted.
4X heads are very likely to crack. Every set I have seen has been cracked. If they are not cracked, I would have hard seats installed in he exhaust if you plan on running them. That will cut out the induction hardening, and make them less likely to crack in the future. But check the chamber CC's first, as they are likely very big, and will be low compression.
64speed 07-13-2017 05:24 AM
I am fairly certain that these are low compression ones. Their only redeeming factor being screw in studs. Oh yeah guys by the way. I am not illiterate I am a night owl and I am typing these messages on my phone in the middle of the night with my brightness turned way down. I have gone back and read some of my threads and even I couldn't understand what I was asking. LOL
hurryinhoosier62 07-13-2017 07:41 PM
Don't worry. The English comp "not sees" don't hang out in here. We ALL make mistakes. Mine are from too big fingers attempting to use small keys.
Half-Inch Stud 07-13-2017 08:43 PM
Good plan
Grand73Am 07-13-2017 10:22 PM
They might not be low compression. What's the secondary stamped code on them?
On 1973 and 1974 4X heads, the stamped codes 3 or 3H, 4 or 4H, and 7 or 7H are around 98 cc, which is a good size for a 455.
Jim Doran 07-14-2017 08:04 AM
Stump Puller link http://www.sdperformance.com/viewPro...productID=1815
1968GTO421 07-14-2017 12:44 PM
Congrats, man! Sounds like you have a great base upon which to build your dream engine. Best of luck to you with your build!
64speed 07-16-2017 01:19 AM
I found a competent machine shop in Greenwood SC about an hours drive from me that has a machinist with an excellent reputation. I called him about my 455's and played dumb on every detail I wasn't dumb about and he didn't try to sell me a line......he told me he could probably make my block with the missing main caps work but he would rather do the block that has its originals. That kinda tells me he's not out to gouge you. I am going to have him do all the machine work but I am gonna do the actual assembly because I want to try my hand at a Pontiac. I have built countless chevrolets including a 409 so with some tech help from you guys I'm pretty sure I can do it. I have been looking at the Scat kits where everything is forged and I have looked at the eagle set where everything is forged but the crank. I am using ARP studs on the mains and the engine will be 30 or 40 over depending what it cleans up at. There is no rust or ridge in any cylinder so I am gonna say hopefully 30. I am looking at the 488 stroker kits and I just wonder if I have my rev limiter set to 5500 do I have to have the forged crank? It's about a 600 dollar difference. I know 600 isn't that much when you're into it like I am but 600 dollars means the difference between me doing things at certain times cause I can only spend so much each month which fluctuates between doctors visit and general household expenses. I am on a fixed income drawing a VA check and I promised my wife I wouldn't use any of her income to do this.
grivera 07-16-2017 08:36 AM
Congrats. You were able to get it "unstuck" with PB blaster and trans fluid the same day you brought it home? Sounds like he seller didn't try anything. Please describe how you did I?
64speed 07-16-2017 12:01 PM
It wasn't really stuck other than a spun rod bearing and some light rust in the cylinders. I keep old transmission fluid whenever I can and I use the old dimple style oil can to apply it. Filled the cylinders that were down with trans fluid with pb blaster and let it sit. After about two hours I dump it so I don't make a mess then I set my snap on impact to its lowest torque setting and just blip it back and forth till the crank spins
Singleton 07-16-2017 01:15 PM
Is the 4.5" stroke crank available in cast iron? All I've seen is forged.
