78 T/A W-72
I have decided to put this car up for sale. It's a 78 t/a w-72 phs documented car. It's all original as far as I can tell. I ran the numbers years back to verify. I have had this car since April of 2005. it does run but it needs an exhaust system and tires. So it has just sat in my shop all these years. I start it up occasionally. It's black with camel tan cloth interior.
$15000 I'm in west central Indiana. |
78 ta
You have a PM.
I checked the VIN# on the block and it does match.
Alternator# 1102854. Date code# 7L14 I can remember checking the transmission and carb numbers and they matched correctly. Brad |
do you have more details? More pics?
I'll try to post more.
I can also text them to you if that's easier. Just pm me a number. Thanks Brad |
[QUOTE=bradrose22;5801711]I'll try to post more.
I can also text them to you if that's easier. Just pm me a number. The car does run. It has a leak from the transmission either around the pan gasket or the fill tube I don't know which. It also has a pinion seal leak. A/C seems to work but the blower motor doesn't blow. It needs exhaust from the headers back. Rust in the upper cowl area, front floor pans. Small amout of rust behind each rear wheel. Solid rockers, trunk, rear frame rails, rear floors. It would be best to just post pics. Brad |
Brad,
Thanks for the detailed reply. I think it may be a bit more of a project than I'm looking for right now. Thanks anyway. |
In addition to the 78 t/a. I would like to add my 73 formula 455 car for sale with it. It's a phs documented car. Original motor and tranny are long gone. This car is totally disassembled. There are a lot of details with this car so it would be best to contact me and talk. I would sell both cars for 22k obo.
Leave me a p/m if interested. I am in west central Indiana. Brad |
These cars are still available.
Brad |
Pm sent
| All times are GMT -4. The time now is 06:49 PM. |
