-   61-63 Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=427)
-   -   4bbl intake wanted (https://forums.maxperformanceinc.com/forums/showthread.php?t=811361)
500plus 11-02-2017 10:49 AM
4bbl intake wanted
Hey guys, looking for a 4 bbl intake for my 61 4 cyl.
Thanks, Bill
Drag Star Le Mans 11-02-2017 03:38 PM
So are you wanting the daul plane style or single plane?
500plus 11-03-2017 08:06 AM
hmm
I guess the 4 cyl is new to me...I didn't know that they offered single or dual!!
c5farmer 11-03-2017 08:57 AM
intakes
The dual plane was used in 1961. A single plane was used in 1962-63.
John in Minnesota 11-04-2017 08:30 PM
I forget, what is the difference? Better or worse what.
Peter Serio 11-05-2017 03:58 PM
If your plan is to convert or build a fresh 195 ci 1bbl 4 cyl engine MAKE SURE that you get the carburetor and all the associated bits and pieces for the throttle linkage when you buy the manifold.
As far as I can recall none of that stuff is the same as the 1bbl carb intakes and if you don't buy a complete 4bbl carb with intake you will likely never find those linkage pieces. There may be other vacuum fitting(s), water outlet and/or wire holder; or aircleaner support brackets that go to a 4bbl intake as well. Best to buy a complete engine or at least the whole set-up rather than just a bare intake.
Drag Star Le Mans 11-05-2017 04:38 PM
Peter gave some good advice. I don't have all the little bits just one of each. I'm going to dig them out and get pictures.
Drag Star Le Mans 11-05-2017 11:52 PM
5 Attachment(s)
Throttle linkage for the 61 daul plain 4bbl will be a problem. I doubt you would have any problems with the 62/63? I'm not desparate and my prices reflect that.
$160 shipped for the 61 daul plain unit and $120 shipped for the single plain 62/62 intake.
mechanickeith 11-06-2017 09:25 AM
Dual plane is a 61 only item. More torque from the 61 manifold. More HP from the single plane. Also,, the single plane is much lighter than the dual.
500plus 11-07-2017 12:56 PM
Looks like after talking to Ken over here at East West, I will not be needing a 4BBL intake after all. I am going to install a draw through turbo setup on this little thing.
Thanks for the replies, Bill
