My sleeper T/A at car show
That's real nice !
Incredibly awesome!
Are you happy with the FITECH system so far?
Tom V. |
Hey Tom yes the FiTech is pretty damm good and easy to setup but there are a lot of parameters in the system that unless you are a tuner which I am not, it can be confusing but with somebody who can understand the terminology of what can be adjusted it would be benifical... my car did not run right with a carb on E85 and now runs great it could be fined tuned better but need to find a tuner to do that because every time I start messing with the pro tuner section of the unit I get myself in trouble ... but I would highly recommend the FiTech system over a carb .
Great to see another turbocharged Pontiac street car, looks awesome!
Looks great!! Keep us updated on the fi tech tuning progress.
Whos E85 carb did you ran? Thanks.
Car looks great by the way! |
Thanks Jeff, I know about the 800 hp on e-85 which sucks ..... at the track I can switch to race gas and retune the a/f stays the same all you have to do is put the correct engine size back in the program , now I add 30% to the size for E85 ....
Do you have any links to your build? Car is awesome!
Sorry I did not keep a build update as I was trying to hide most of it from my wife 😂 but I can answer any questions about the build if needed
I'm most interested in how you have your manifolds, wastegate and oil feed/return lines routed.
Did you utilize a water jacketed center section? |
Thanks, that's absolutely helpful!
Tom V. |
Thanks Tom , hey do you think having a 3.5 “down pipe going into 2 - 2 1/2 “ pipes is a restriction on hp ?? Is a 3” exhaust system in order ?
On my setup, I have a 5" downpipe about 2 feet then neck down to 4". Then I'm going to do a two 3" pipe to the muffler. This is with a PT91.5 G trim single.
NA two 2.5" pipes support 500 hp with NO restrictions. Two 3" around 700 hp before it starts to restrict. You can certainly make power above those levels, but that's the @ power level those pipe sizes support before they start creating restriction.
Starting out at 5 and gradually reducing helps reduce back pressure. The turbine will like lots of expansion at the exit, so don't get shy if you have space for BIGGER! |
1) ALLOW THE SWIRL FROM THE TURBINE TO CHANGE FROM ROTARY MOTION TO LAMINAR FLOW. 2) REMOVE MORE HEAT FROM THE EXHAUST IMMEDIATELY AFTER IT EXITS THE TURBINE (MORE SURFACE AREA TO COOL THE EXHAUST. You really only need about 12" of length. Example: A 12 inch piece of pipe 4 inches in diameter will have 150 cubic inches of volume to convert from Radial Flow to Laminar Flow. It will also have a large enough surface area to cool the pipe flow so that the exhaust has a denser volume and can pass thru a smaller diameter efficiently. Going massively long on the length really just allows the exhaust to pack up in the volume and disrupt flow. Tom V. |
| All times are GMT -4. The time now is 09:37 AM. |
