-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Deck dimensions / blueprint (https://forums.maxperformanceinc.com/forums/showthread.php?t=817607)
455-4+1 04-30-2018 01:33 AM
Hi there, getting a torque plate made over here in NZ, couldnt find one locally and really dont want to ship one 1/2 way accross the world!.
I have measured off a couple of sets of heads but am getting small errors that dont seem to add up for bolt holes and bolt offset from bore.
I have input the data into CAD, but would like to check a few key dimensions off the original design if possible, happy to return a.dxf file if anyone only has scans or paper copies for the favour.
Cheers Don
gavin 04-30-2018 03:35 AM
I made mine off a head gasket and it works well. The main hassel is to get the location holes right. I used 1 1/4" gas cut a wee bit small I then drill all the holes and bolted on to a block .I then got the engine shop to bore it on the block indexed off the bores 090 bigger than a 455 bore. It works pretty good.
krisr 04-30-2018 06:02 AM
Hey mate, if you want to send me the DXF file, i'll check your dimensions against a 64 block I have downstairs if you'd like. I've been meaning to draw up a torque plate myself for any engines that I do now as no machine shops over here have one in AU. What did you use as your datum? the front or rear of the block?
RA462 04-30-2018 12:39 PM
I have this picture I saved from somewhere. I don't know how accurate the measurements are but if I remember correctly it came from Cometic. Hope it helps.
azbirds 04-30-2018 07:50 PM
I also used a head gasket to make mine. Made it out of 1.5" 6061 plate with a bore of 4.375. Worked great.
Jack Gifford 05-01-2018 01:21 AM
2 Attachment(s)
Originally Posted by RA462;5876841 ...
I have this picture... if I remember correctly it came from Cometic. ..
Yes, that's the one I posted that's from Cometic. It's accurate. This image might be a little clearer.
But that page doesn't totally show dowel locations, so here's the other page. Note the subtle .010" difference in dowel locations.
455-4+1 05-01-2018 09:34 PM
Thanks guys, will make a few adjustments to my file and see how it goes
tc 05-11-2018 08:09 PM
A little late, but here is what I measured from my block
455-4+1 05-12-2018 03:21 AM
Cheers, pretty sure i got things sorted. Thanks for the images, i to making chips 😁
Tracy G 10-15-2025 08:34 AM
Pontiac cylinder and head stud locations
DO anyone have the pontiac cylinder and head stud locations?
Tracy G 10-15-2025 08:36 AM
Thank You!
