-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Excessive oil under dist.cap (https://forums.maxperformanceinc.com/forums/showthread.php?t=818534)
badgto 05-29-2018 10:19 PM
Has anyone experience excessive oil inside distributor cap and know why or how to control it? I run a msd billet dist that's about 8 yrs old. With a oil feed hole for gear and also run a vacuum pump with about 14" vac at idle. I have cleaned under the cap 2 weeks in a row
With same amount there. I run a crank trigger set up too. I have taken the distributor completely apart and seem tight with no play.
Keith
mgarblik 05-29-2018 10:26 PM
With a vacuum pump system, this is a little puzzling. We had oil in the distributor issues with a Mallory distributor years ago. That distributor had a large 1/4" feed hole into the shaft area. I tapped it and screwed a .060" restrictor in that hole. That took care of it. It was fine on the drag strip. Thousands of street miles could be a problem.
Probird 05-29-2018 10:27 PM
Pic of Badgto’s distributor
badgto 05-29-2018 10:31 PM
This distributor had never been used on the street. I have use this oil feed plug bef ore no issues.
chiefbigb 05-29-2018 10:37 PM
There is a seal in the top of it. Could be your problem
badgto 05-29-2018 10:43 PM
The only thing I see at the top of the dist body is brass insert and the shaft rides on 2 thin brass washers. Does the seal have any rubber lip or anything to help seal?
chiefbigb 05-29-2018 10:46 PM
I replaced one a while back. Yes it's a lip seal. I remember there was roller.bearing in that area to.
badgto 05-29-2018 10:49 PM
Does msd make a kit that you can buy?
[email protected] 05-29-2018 11:54 PM
Keith i have one that you can borrow if needed
chiefbigb 05-30-2018 06:56 AM
Got the parts from a local speed shop that was a msd dealer. You could more than likely get them strait from msd.
badgto 05-30-2018 06:59 AM
Thanks for the help.
Gary H 06-21-2018 08:03 AM
Bringing this subject back up because I have a stock Pontiac distributor in my race car that is leaking oil into the cap as well. Is there a seal in the stock distributor anywhere that could be going bad? I have a vacuum pump but it's still leaking.
steve25 06-21-2018 08:18 AM
I assume your block plug is drilled to oil the Dizzy and Cam gear, and if so to what size?
Gary H 06-21-2018 08:08 PM
No, it's not drilled to oil the gear. Race only engine with BOP gear.
steve25 06-22-2018 06:18 AM
Big nose up lunches and no rear of pan baffle plate ,or baffle plate alone on the rear main cap studs can send a ton of oil right up into the Dizzy!
