-   Pontiac - Boost (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=495)
-   -   EFI w/Dual plane manifold (https://forums.maxperformanceinc.com/forums/showthread.php?t=818728)
67 455 Bird ragtop 06-05-2018 08:30 AM
I've read a few posts that the new EFI systems, Sniper/EFITech don't really like a dual plane manifold. I currently have an Edelbrock Performer RPM which is a dual plane manifold. What are my option?? Or is this not really an issue with the RPM ??
Steve C. 06-05-2018 10:19 AM
Subject discussed here.....
https://forums.holley.com/showthread...l-Plane-Intake
67 455 Bird ragtop 06-05-2018 11:22 AM
Originally Posted by Steve C. (Post 5890628)
Thanks. That was helpful ..
Lee 06-05-2018 02:04 PM
I put a FAST EZ 2.0 on a 455/PerfRPM for a friend, and it has ran great for about 2 years now.
Another EZ2.0 inst on 350 chevy, Perf EPS also ran great. I added a 2" open spacer and no differences anywhere.
I plan on testing several different intakes on my own 455/efi, on a chassis dyno, in the near future. Right hand is in a cast now though, not sure when I'll be healed enough to do it
67 455 Bird ragtop 06-05-2018 03:31 PM
Would cutting a notch between the two sides make any difference ??
Lee 06-05-2018 04:25 PM
first, try it unmodified. if no problem, then leave alone.
Next I'd try an open spacer. If that doesn't make a difference, then a notch won't either.
JLMounce 06-05-2018 04:33 PM
I ran my FiTech on a P4B for about a year and a half before changing my top end and going to a torker ii.
It ran fine on the dual plane manifold. There were a few cylinders that had a bit of distribution change over the other cylinders, but nothing that would cause any concern, or register any power loss on the butt dyno.
Run what you have, change it only if you notice a problem.
67 455 Bird ragtop 06-08-2018 06:32 PM
Sounds like the old "If it ain't broke don't fix it" is the way to go.
