-   Performance Parts For Sale/Wanted (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=446)
-   -   Tanks, Inc. - 71-72 (73) GTO/LeMans (https://forums.maxperformanceinc.com/forums/showthread.php?t=820543)
leeklm 07-29-2018 09:29 AM
Like new Tanks Inc. fuel tank, pt. # TM34I-T - Includes new straps
Price w/o pump & float = $120 + shipping
Price with 225L/hr pump & float (no lines) = $230 + shipping
In case you have a 73 GTO/Lemans- this part number fits perfect!!
mchell 07-31-2018 12:08 PM
Pm’d You
leeklm 07-31-2018 12:33 PM
Sorry- I am not able to reply to PM messages due to the Forum/Site issues currently going on. Will keep trying...
mchell 07-31-2018 01:15 PM
I figured....looks like they are having some issues
I’m interested in your tank/pump for my 71 GTO.
did that setup work for you?....were you using it with a carb?.....noisy?......how old is it?
mchell 07-31-2018 01:58 PM
cdrookie 07-31-2018 04:20 PM
I sent a PM wanting the LPW diff cover leeklm, do you still have it?
leeklm 07-31-2018 06:30 PM
Hey Guys, yes, messages received. feel free to email me at [email protected] and we can square away the transactions.
Regarding the Tank... I love these units, and will likely be running one in the 68 firebird. They are baffled, work great for drag racing (at least it did for me), and the pump noise is barely noticeable. In fact, if your car makes any rumble at all, you will not hear the pump! Nothing like the typical Holley external race pump.
I ran mine with a RobbMC regulator feeding a holley and qjet. 3/8 steel line feed and return. I used it for about 3 years and maybe 5,000 miles at most.
leeklm 08-07-2018 08:37 PM
Tank and pump still available. Complete with matching straps and filler neck.
Scarebird 08-07-2018 10:21 PM
The pump, what psi? And ohmage range for the float is 0-90Ω as per stock?
leeklm 08-08-2018 10:28 AM
Pump is their GPA4, which is 255 ltr per hr, and about 80psi. Rated to support 630hp via fuel injection, or approx 700hp via carb.
I am pretty sure the sending unit uses the correct factory resistance, as it worked fine with my factory fuel guage.
Sent from my XT1585 using Tapatalk
Scarebird 08-09-2018 06:14 PM
excellent, thank you.
bobby326 08-14-2018 06:41 PM
The frame is basically the same so i would think it would fit but would you know if this tank would fit a 67 Lemans.. I know the detentions are a little different.
leeklm 08-14-2018 07:15 PM
Sorry I do not, I could provide a few pics and measurements so you can compare, or maybe can compare on tanks site.
Sometimes only the filler neck is different. If that is the case, you can cut your old filler neck off, and use the adapter hose and clamp to secure to the new Tank. This is actually the way they do it when supplying you with the new Tank and neck.
bobby326 08-14-2018 08:59 PM
Thanks Tomorrow I’ll take the measurements and check to see if it will fit.
bobby326 08-14-2018 09:01 PM
Where are you located/ shipping from
leeklm 08-14-2018 09:59 PM
Mpls, MN. Quoted another guy about $60 to ship to FL, based on UPS calculator. Here are a few pics if it helps...https://uploads.tapatalk-cdn.com/201...10e7690ffd.jpghttps://uploads.tapatalk-cdn.com/201...f064e288f6.jpghttps://uploads.tapatalk-cdn.com/201...9c4bd40cfc.jpg
