Swap a 63 auto trans to a 62?
Can you swap a 63 auto transaxle into a 62 model? I know the main difference is the 63 has the "park" feature but is there any other dimensions issues that won't allow the swap? Thanks
can't do without modifying the axle's! The 63 differential is 1.5 inch's wider than the 62. I ran one for about a year. I had to cut a half inch out of each axle to make it fit.
Thanks Jay, I thought there might be an issue.
| All times are GMT -4. The time now is 04:22 PM. |
