-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   My New Pump Gas 505! (https://forums.maxperformanceinc.com/forums/showthread.php?t=821360)
grandville455 08-22-2018 06:49 AM
Dynoed the new motor yesterday, made 8 pulls, last one we tried 26 degrees, 7th was the best for the day@28 degrees timing and 112 BLP jets, we stopped there as it was heat soaked, hopefully finish it up later today and pull it higher to see what it looks like up top, I'm totally stoked with the new build and the early numbers its showing! 91 Octane and same KRE D Ports from last motor
https://i.imgur.com/i9y3WiB.jpg
johnta1 08-22-2018 07:21 AM
Looks great!
Congrats!
LiL Jack 08-22-2018 07:22 AM
Very nice
Gary H 08-22-2018 07:40 AM
Very impressive! I see that it liked 29 degrees timing best, and I've read and heard others say the same thing. For some reason the engines I've built with those heads always showed they liked around 32 degrees best on the dyno. Don't really know why. Congratulations though, great numbers!
PAUL K 08-22-2018 07:44 AM
Good job Darby! Nice build.
Scott65 08-22-2018 07:45 AM
Congrats, good job
PONTIAC LARRY 08-22-2018 07:46 AM
Awesome !
Hooter 08-22-2018 08:08 AM
Something I've learned from a few dyno sessions - be sure to use you own timing light at the dyno session and not rely on the dyno operators light. I had an experience where there was a slight difference between the 2(his was a dial back and mine a old conventional). Great numbers either way.
grandville455 08-22-2018 08:11 AM
Thanks Brad! I agree, I brought mine to use, and once were done i'll verify what mine says compared to his, and well also be using my digital7 ign box and coil, that way its how it is when in my car, yesterday was his 6al analog box and tower coil, and we only did that cause we knew it worked to get the tune in order for the most part.
BruceWilkie 08-22-2018 09:30 AM
Nice
Did you just up displacement and maybe cam change?
Will be interesting to see how the car picks up.
AG 08-22-2018 09:31 AM
Great numbers. What is the cam and what are BLP jets? What was the BSFC numbers?
OCMDGTO 08-22-2018 09:35 AM
Awesome congrats! What cfm on the heads?
Skip Fix 08-22-2018 09:47 AM
Good numbers! Now get that thing in the car for some shake down runs!
grandville455 08-22-2018 09:58 AM
Bruce, Cam change also, 55mm LSM Cam, Ls FIRING Order, .904 morel bushed lifters
grandville455 08-22-2018 10:01 AM
55 mm LSM cam, ls firing order, 270/276@112 LSA, Bolaws Performance carbs .112 orifice size, The one earlier pulls showed a avg of .415!! She's efficient as hell!
grandville455 08-22-2018 10:03 AM
Heads on a tight flow bench and a 4.18 bore were 325@700, Probably about 335-340 on this bigger bore.
grandville455 08-22-2018 10:04 AM
Thanks Skip! That's the next plan after we find its final numbers, we haven't even pulled the covers and relashed the valves yet :)
Scott Stoneburg 08-22-2018 10:11 AM
Great numbers bro.
hurryinhoosier62 08-22-2018 10:44 AM
Nice results, Darby!
Sirrotica 08-22-2018 10:52 AM
Darby, so how fast will it push the Grandville, instead of the Firebird?...……….LOL
BTW nice numbers!!!
