-   Pontiac - Boost (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=495)
-   -   Carb hats and lean back cylinders (https://forums.maxperformanceinc.com/forums/showthread.php?t=823925)
er455 11-07-2018 05:56 PM
Ok so I have noticed that my rear cylinders are running a little leaner than the front and from what I have been hearing is that the carb hat needs to have a big spacer under the hat so the air has time to straighten out before entering the carb / throttle body , but the hood clearance is not really available. Has anybody tried make a deflector inside the hat ??
er455 11-07-2018 06:04 PM
Carb hat
Here is a pic of what the Buick grand national guys use .. when you look at it it looks like it would be counter productive as it looks like it’s choking off air flow , but guys are running in the 9 second ranges with them and it solved the rear lean cylinder condition. maybe something could be made for a carb hat , just thinking outside the box ....
JLMounce 11-07-2018 06:05 PM
You run a FiTech correct? What intake manifold do you run and how much psi are you pumping through it?
er455 11-07-2018 06:06 PM
Yes fitech 1200 right now 12 pounds on E-85
er455 11-07-2018 06:07 PM
With a ported tomahawk intake
JLMounce 11-07-2018 06:11 PM
Okay, that rules out distribution issues caused by a dual plane manifold. You could look into an enclosure which is supposed to help, but I'm not certain how or if that would even work with a FiTech.
Another thing that may help is larger intake piping. Increasing the tube diameter size slows down the air velocity and aids in keeping it from slamming into the back of the carb hat. To my understanding that's what typically causes the lean condition. However that's typically due to airflow signal through the venturies on a carb. The FiTech doesn't really care about that. Have you looked into a turtle for the plenum in your tomahawk?
er455 11-07-2018 06:13 PM
Another pic with different angle ...I already had to modify the hats inlet and it barely rubs the hood scoop now
er455 11-07-2018 06:19 PM
Thanks Jason I have not looked at the turtle , I talked to Steve Morris and he likes to have a 2” or bigger spacer under the hat but I do not have the room .
er455 11-07-2018 06:22 PM
Sorry about the rotated pics
JLMounce 11-07-2018 06:38 PM
How much leaner are the rear cylinders than the front cylinders? Can you tune around this by fattening up the entire mixture to deferentially make the rear's richer without going too rich on the front cylinders?
er455 11-07-2018 06:42 PM
Hard to tell but the plugs are lighter on the rear , I like that idea of running richer across the board plus it will be a safer tune as well.. thanks
JLMounce 11-07-2018 06:45 PM
That's probably the simplest way around it.
Interceptor 11-08-2018 10:33 AM
When I was running turbo Buicks we had the same problem. A guy came up with a spacer plate with shapes cut into it to even the flow. Funny looking thing but ... no more blown rear headgaskets. Here are some examples. They would have to be pretty specifically designed, or else they would just move your lean issue to another cylinder.
https://gbodyparts.com/product_info.php?products_id=561
BruceWilkie 11-13-2018 08:47 PM
Dual inlets facing each other might resolve this. "Deflectors" made with 1/4" mesh screen should break up swirl and keep things more turbulent and help as well.
Tom Vaught 11-13-2018 09:00 PM
I did a bunch of testing with wire screens Bruce and never found that they actually straightened the air. You needed "FINS" (like a wind Tunnel has in the corners of the tunnel loop) to turn the air in the direction you want it to go.
A basic House fan with 1/2" squares 3/8" thickness on the fan frame just keeps kids fingers out of the fan blades. No real effect, wire screen even less effect. The wire screens on the old mass air meters were there to keep "rocks" from damaging the Meter.
That being said, your dual air feed system across from each other works every time.
Tom V.
v869tr6 11-14-2018 03:48 PM
Are you talking new plugs that are looked at right after a pass and not driven back to the pits?
er455 11-15-2018 09:28 AM
no I just took them out to change and noticed that the back were leaner looking than the front , did a little research and found that a lot of hats that fit under hoods have this issue .,
JLMounce 11-15-2018 10:28 AM
Yeah I would make a pass, immediately shut the engine down and pull a couple plugs to verify. Under load is where this is going to be the biggest issue. Verify it's present in that situation vs. idle/cruise.
