Clearance windage tray around main caps?
'67 400, 4" Scat crank, Pro-Gramm main caps with ARP studs.
3/4 length Tomahawk windage tray, Canton oil pan. Issue is the windage tray hits the ARP studs before the retaining bolt holes mate up with the tapped caps. About 3/8" standing off, too much to shim IMO and besides, the tray hits the oil pump at that height too. Do I drill out the tray and let the ARP studs poke through? |
Yes, you can drill it out, but do it in steps up to the needed clearance for the 1/2" studs.
whike your at it round out any sharp corners in regards to the sheet metal as these provide places for cracks to start off. |
| All times are GMT -4. The time now is 02:18 AM. |
