-   69-71 Judges only TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=434)
-   -   1969 Judge Engine block (https://forums.maxperformanceinc.com/forums/showthread.php?t=836748)
grahamp 12-29-2019 07:25 PM
Am I right in thinking that the early 1969 Judges used the two bolt 9790071 block which was later changed to a four bolt set up, the 9799914 block? Appreciate any information on this. Many thanks
thepontiacman 12-29-2019 07:52 PM
69 RA3 are 2 bolt main. RA4 is 4 bolt main. 9792506
0071 block for 69
9799914 used in 70. both 70 RA3 and 4 are 4 bolt main. 9799915 RA4
grahamp 12-29-2019 08:37 PM
Pontiacman, many thanks
grahamp 01-02-2020 06:23 PM
1969 GTO Ignition upgrade
I recently installed a Pertronix Ignitor in the distributor and threw out the points! Works perfectly except that the hood tach no longer works. Has anyone been able to solve this problem
kyle_blake 01-03-2020 03:49 AM
i think the manual says you need a resistor wire in series on the tax lead?
