HEI Center Plate
I had the cap off of my HEI and decided to clean and lube things. I noticed the weights were 139’s. I find no ID on the centerplate at all. Is there a way to determine what it is otherwise?
Take the center plate off, and flip it over- it should be stamped on the bottom side-
“At all”
David is this a “new” hei? Offshore?
If so can you post a pic of it? Bet it’s an unhardened, generic if there’s no numbers on it. All GM HEI had numbers on the advance parts. Fwiw |
Unless it’s one I did awhile back. Got a pic?
Yup, they can ware darn fast if they are not hardened!
Don't fret, as it's easy to temper them harder at home with a propane torch. |
http://forums.maxperformanceinc.com/...1&d=1579699347 |
It took a little thinking back, but I believe this one was set up for my 400, which liked a LOT of initial. 18. I took the dist I had in the current 455 out (Pertronix?) and put this one in about 3 years ago and before I could do anything A guy hit the GTO and it spent the next 1.5+ years in body shop jail. Then , fairly immediately after I got it back, I tore my shoulder up and have spent the time since then dealing with that. Today I go to a shoulder specialist to see about a replacement, but that’s a different story.
My intention when I opened it up was to lube things and see what centerplate this had and adjust from there with a trip to the Pull A Part this Saturday. It currently has about 14/15 degrees mechanical and I’d like 20/21. I’m not sure what the surgical schedule is gonna be, but once that’s done, I’m probably out of the working on the GTO business for a good while. :) |
That’s one of mine.
Not sure where the springs went but I looked back and originally that was shipped with 12 in the distributor (24 crank degrees). Depending on the springs that were on it when you last checked it they could’ve been light enough to allow some override. The springs I had originally on it would have alleviated that issue. If you need some more just let me know in case yours got ancy and ran away. |
Before I fool with it further, I’ll lube it a bit and then test the spread again. Maybe Saturday. Lube? I’ve read yes lube and also no lube. Just clean. What’s right? Many thanks. Surgery Feb 3rd. Reverse replacement. He said six weeks and I’d be good to go. |
Sent from my SM-G973U using Tapatalk |
I can’t seem to get 14/15 crankshaft. I’m looking for more.
Lube? Apparently my memory is short. http://forums.maxperformanceinc.com/...39#post3572739
See the tech thread archive Sticky link at very top of this section. Scroll down 13 topics and click.
That’ll get you hooked up on lube. Little 30w or so on the pins for up north or little grease for down south and you’ll be good. I prefer the oil period. |
Well I think we got something sticky somewhere. That thing should put 24 on the crank out there with ease. Not sure yet what’s going on there.
FWIW those of you wanting 10 in the distributor can use a factory 389 stamped center plate. If you’d like a degree less find a set of 045/053 weights to go with it. Since that’s a 24 crank degree cam and your only seeing 14/15 I’d say there is something sticking or maybe the dial back function on the light being used is being a touch tricky. With the shoulder thing getting in the way I understand but you know I’ll fix it if there’s something other than the light causing an issue. Nobody beats my warranty on these things. I’d send you a “more “ center cam but you already got the “most” I ever had. Get that shoulder well and we look further into this... |
| All times are GMT -4. The time now is 10:16 PM. |
