64-67 GTO A/C Radiator Supports!
2 Attachment(s)
Very soon, AC radiator supports will soon be available! GTO owners have been stuck spending stupid money for rotted used ones for years...Now we created a new solution.
A. Lower AC Support Panel: We will be offering the lower AC support panel piece by itself. Drill out the welds in your non AC original support. Then re tack in this lower channel piece. Wha lah! You now have an AC support that is capable of fitting the taller 17.5" radiator. B. AC Support: We will also be making our own full supports. We will take a reproduction non AC support and convert it to an AC version with our lower support panel. For those not wanting to do the grunt work of modifying their originals. Our production run is happening now so look for these pieces at Pontiac dealers later this Spring! |
Awesome, thats great news, thanks.
Any update on this amazing project?
b) full AC supports will be ready in May. We're doing them in house with limited staff. So if you want one, it's best to call in and get one ordered. |
Do you have these for 64
We do not plan on making the 1964 full support. The reason we are offering the 66-67 AC support is because the non ac support has been reproduced. So we are using those to make the 66-67 AC supports. |
Lower a/c bracket availability
Are these brackets still being produced?
they are no longer in production but there is still inventory of the last production run.
Very nice. I think I need this.
i will warn you that they are not easy to install. They have to be precisely welded. You'll need to make some kind of jig to assure the proper location.
Chris
do you have any of these left? |
| All times are GMT -4. The time now is 11:08 AM. |
