1971 Formula 455HO
5 Attachment(s)
I found this car in Medford Oregon last June. It wasn't advertised, but I received an email from a guy I knew who told me the car belonged to a "friend of a friend" who was thinking of selling it. Needless to say, as soon as I found out about it I jumped in my car and took a road trip to Oregon.
The car was originally from Ontario Canada, and from some of the work orders I received with the car, it appears the car was in the Trenton Ontario area until at least 1994. Sometime after that the car went to Long Beach, Washington. In 2015, the owner sold the car to his cousin in Medford, and I bought the car from him. The car was built in the Norwood plant during the second week of February 1971 (02B). The GM of Canada Vintage Vehicle paperwork (PHS) shows that the car was shipped to Hogan Pontiac Buick Ltd., Toronto, Ontario, Canada on February 12, 1971. The invoice shows the car was equipped as follows: A01: GLASS TINTED - ALL WINDOWS B42: MAT, LUGGAGE COMPARTMENT FLOOR COVER B80: MOLDING, ROOF DRIP B85: MOLDING, BELT REVEAL B96: WHEEL OPENING MOLDING C24: WIPERS - RECESSED PARK C49: DEFROSTER: REAR WINDOW ELECTRIC D35: MIRRORS: LT REMOTE AND RT MANUAL CONTROL - CUSTOM SPORT D55: FRONT COMPARTMENT FLOOR CONSOLE G80: REAR AXLE: SAFE-T-TRACK H05: REAR AXLE - 3.73 RATIO J50: BRAKES - VACUUM POWER LS5: ENGINE: 455 CID - 4BBL - HO V8 M22: TRANSMISSION - 4 SPEED MANUAL HEAVY DUTY - CLOSE RATIO N30: STEERING WHEEL - CUSTOM CUSION N41: STEERING: POWER (VARIABLE RATIO) PM7: TIRE: F60-15-B (2+2) BB B/WALL WHITE LETTERS P05: WHEEL HONEYCOMB U05: DUAL HORN U30: RALLY GAUGE CLUSTER, CLOCK & TACHOMETER U58: RADIO: AM/FM STEREO PUSHBUTTON V01: RADIATOR: HEAVY DUTY WU3: HOOD - RAM AIR INDUCTION W54: DELUXE TRIM GROUP (BUCKET SEATS) W66: MODEL OPTION: FIREBIRD FORMULA W84: ADDITIONAL FUEL FOR DELIVERY Z49: MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS The formula steering wheel and rear spoiler are not on the invoice, so they've been added at some point. The VIN stamps on the engine block and transmission case match the car, so they're original. The heads, intake manifold, exhaust manifolds and crossover, carburetor, distributor, air cleaner, cooling fan, radiator shroud, and alternator are all correct and probably original to the car. The rear axle gears have been changed to 3.08’s, (which I don’t care for). I doubt I’d put the 3.73 gears back in it, but I like the 3.42’s in my trans am, so I’ll probably put a set of those in this car. The master cylinder is an aftermarket, but the original (EB code) master was in a box in the trunk. The radiator is incorrect, but I have a correct four core manual trans (FP code) radiator in the attic, so I’ll be installing that. There is an aftermarket am/fm cassette deck in the dash, but the original am/fm stereo radio and faceplate came with the car and they're in nice condition. The car has a mini starter in it, so unfortunately the 1108436 starter is missing. Other stuff that’s missing are the bumper jack, trunk mat, wheel opening moldings, and the rocker moldings. The rear leaf springs are incorrect, and the car sits too high in the back for my liking, so I'll need to address that. The tires on the car are 225/60/15’s, which are too small, so I need to get some bigger tires to fill out the wheel wells. Sheet metal wise, it looks like it’s all the original stuff, and the body is really solid. The odometer reading is 65,682, and considering the condition of the car, it would not surprise me if that was the original mileage. The car has had an inexpensive repaint, and the color is just a bit too dark. The original color is Lucern blue, but it now looks more like Atoll blue to me. The interior is black deluxe. By coincidence, my 1971 Trans Am is also an 02B Norwood car. The body sequence numbers are only 684 units apart, so these two cars were built pretty close to each other (time wise). The date codes on the two cars are within days of each other on many of the parts. Both cars were shipped to Ontario Canada, with the Trans Am going to GM of Canada in Oshawa, and the Formula going to Hogan Pontiac in Toronto, a distance of about forty miles from each other. |
5 Attachment(s)
More pics...
Looks like a great car.
I think the word is SCORE! Nice looking car. Good luck with it.
Some times buying a car like that turns out to be a really good transaction. Instead of even buying a car off this site that turns out bad. You know the story you get verbally and then there is the story the car tells you. Both stories are different. At any rate, looks like a really good condition car. Jim |
You mentioned the car had a cheap repaint. Is there any of the original paint on the bottom side of the trunk lid?
Beautiful car! Lots of cool options.
The 70 Mustang and the Saleen Fox are also sweet! |
Very Nice!
wow, congrats on such a nicely optioned car!! It looks like a once in a lifetime find!
Lov'in it! best color combo, M22, non AC, gauges...
Glad you pulled the trigger Chris. |
3.73 in 71? I didn’t know that was even an option. Nice
Sent from my iPhone using Tapatalk |
Cool Chris!
When you can give us some dates on those parts. What's the Alt number 927 or 928 with rear defogger. |
Congratulations. A very nice score and you should be thrilled. I look forward to seeing what you with the car. Much more rare than a TA and it only lacks the Y99 Handling Package.
Looks very presentable like it is. I would focus on getting the mechanical bits and small details right and drive the wheels off of it. Of course this comes from a guy that blew a perfectly fine ‘72 Formula 455 HO into a million pieces and made it too nice to drive. Whatever you do, it’s your car and I hope you enjoy it. |
2 Attachment(s)
Nice find with great options! Good to see that it wasn't destroyed here in the southern Ontario winter weather.
Cool to see the Canadian Forces Base Trenton sticker too. https://forums.maxperformanceinc.com...6&d=1581265832 https://forums.maxperformanceinc.com...0&d=1581265894 Quote:
Would be cool if they still had paperwork for your car; might be worth a call (416) 291-5054 even though they moved from the Danforth to Sheppard Avenue East in the early 80's . Photos of Hogan Pontiac Buick (Acadian GMC Vauxhall) circa 1968 and 1972 below. Grand Prix, Lemans, and Buick Wildcat to name a few are visible. There may be a possibility to get the prior owner's names (from Ontario only) with the VIN. If you want me to look into it Chris, send me a PM. |
Beautiful ride and well optioned car. Gotta love the M22 in any ride let alone 455HO.
Hope to see it in Dayton Ohio this year at the nats. Its worth the trip especially with a ride like that. I think they even give an award for those who travel the furthest away. |
Congrats, Chris - definitely a holy grail car! And a perfect pairing with your T/A :)
Awesome looking Formula!
Need more pics of that 93 Saleen SSC.. probably the best looking Saleen ever made. |
Wow Chris! One of the very few with digger gears and Ram Air from the factory! That is such a great find and numbers matching just adds to the WOW factor. Congratulations!
Interesting that it doesn't have the Y99 handling pkg. that BWB pointed out, but has the 15" HC wheels. Is the N30 Steering Wheel - Custom Cushion not the Formula Wheel? How is the sheet metal? Dennis |
What an amazing car and score for you. Perfect drivetrain combo and no AC. Out of curiosity have you verified smaller Formula sway bars? Like others am surprised at the no Y99 with the big honeycombs. No matter, just a perfect option and color car. "WOW".
wow!!
looks like you hit the jackpot!! Congratulations!! |
WOW very cool car!
| All times are GMT -4. The time now is 10:01 AM. |
