-   67-79 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=431)
-   -   Rear Tail gate window 67 Catalina (https://forums.maxperformanceinc.com/forums/showthread.php?t=838716)
Petegto 03-14-2020 07:29 AM
Can someone tell me if there is a separate switch that operates the rear window on my 67 Catalina wagon? From the dash the tail gate window goes up & down but when you use the key in the gate it doesn’t work. If you have a picture of the switch that would help and location.
Thanks Peter
goatless 03-14-2020 08:59 AM
I believe the the "other" switch is at the key location, mounted on the inside of the tailgate operated directly by the key. I had a '69 Bonneville wagon that should have been the same. It's been a long time since I had the tailgate apart, so my memory is a bit fuzzy.
There is a removable panel on the tailgate that you can open up to gain access to the switch. It's kind of a pain though as the glass has to be up to access the switch, but the gate won't open if the glass is up and the glass won't go up if the gate is open.
Petegto 03-14-2020 02:52 PM
Thank you I will give it a try but you’re right don’t think there’s a easy way to get access to the switch.
Peter
A390GT 03-16-2020 02:39 PM
I have the same problem with my 68 wagon. The switch on the dash works both up and down but the gate key switch isn’t working. You can get to everything from the access panel on the inside of the gate. You have to have the window rolled up to gain access to the switch.
I still haven’t figured mine out, but it might be a switch that doesn’t let the key work unless it’s in the gate closed position.
John-
Petegto 03-16-2020 07:07 PM
67 Catalina wagon
Thanks John I tried all the ways with gate up and inserted the key. I don’t even hear a click or any sound that the motor even trying to move. I know the gate has to be closed before it will work regardless.
I’m going to try and just replace the switch if I can get it out; I’ll let you know if I’m successful.
Thanks again
Peter
Petegto 03-23-2020 04:40 PM
67 Catalina wagon switch
Does anyone know where I can buy a rear window tail gate switch that operates the window with the key?
Peter
north 03-24-2020 10:30 AM
2 Attachment(s)
Before you go out to buy a switch I'd first concentrate on power supply, make sure that the switch is properly connected and also test-inspect the wires that run from the switch to the window motor. Even if it turns out that the switch is the problem it is very likely that it just needs cleaning of the contacts.
Here is a pic for your reference. As previously mentioned you need to lay the tailgate flat and through the tailgate latch so the window can be opened by the dash switch. (remember to support the window when you open it in that horizontal position.
Petegto 03-25-2020 08:31 AM
Thanks North for the great advise I will try that first before trying to purchase another switch. I thought there were 2 switches that worked the window 1 from the key end and other from dash.
So I should be able to get to the switch in the tail gate in the down position and raise the window.
A390GT 04-16-2020 12:28 AM
2 Attachment(s)
Hey peter this is on eBay.
He has the roof rack still on the car and possibly the tailgate switch
I need rear door panels in the ivy color so I sent him a email
John/
Petegto 04-16-2020 06:28 AM
67 Catalina Wagon
Thanks Hohn let me know what you find out maybe we can do something here. A lot of options that I don’t have.
Peter
Jeff Hamlin 04-16-2020 07:57 AM
'67 FISHER MANUAL
FWIW; If you don't already have it here is the Tailgate Power Window section that may be of help.
http://thefirstgensite.com/library/6...7S16P14_25.pdf
A390GT 04-16-2020 09:13 AM
It was about 1,500 to have a running wagon shipped from Arizona to nj
I’m not sure how to get a shell here from
Oregon.
That was a crazy optioned wagon... too bad it’s so far gone
That 3.08 safe-t-track is calling my name...
My big is I need the door cards and the switches then I can add power windows to the wagon .
Do you have any friends in Oregon?
https://www.ebay.com/itm/352607901926
I’ll let you know what he says
Petegto 04-16-2020 11:09 AM
67 Catalina Wagon
John no friends out that way but let’s see what he says.
Jeff thanks for the information on the tailgate wiring I didn’t have it. I’ll let u know how I make out.
Peter
kpbrown31 05-02-2023 05:18 PM
Anyone found an aftermarket substitute that can be put in place for the dash window switch? I’m not dead set on a factory look. But thought maybe something could be rigged up to fit into the old switch plate and be a reliable sub. Mine was super corroded and bad.
Petegto 04-10-2024 01:03 PM
67 Catalina wagon tailgate information
Would someone have information or website regarding the tailgate electrical section on my wagon? I had it 4 years ago when I fixed the power rear window but can’t seem to remember what I did with it.
