Beautiful Lucy Blue 71 For Sale on EBay
This one just popped up at a Dealer in Utah. Three owner, full restoration. $129,950 BIN and 80+ high res photos. Beautiful car!
https://www.ebay.com/itm/19341051761...&ul_noapp=true BJ |
Wow - sharp looking car!
The paint they used looks a bit more like Adriatic than Lucerne to me, but that's probably just the images / computer. |
It looks like my Lucy Blue 71 in shade.
Were the emissions call out decals placed on the fan shroud? I have an extra core support off another 71 and that is where it is. |
5 Attachment(s)
Detailed description on line too ; excerpt below
"... all numbers-matching, rotisserie restored & heavily documented 1971 Pontiac GTO ‘The Judge’ 455 H.O. Hardtop Coupe! ... A 3-year comprehensive nut & bolt rotisserie restoration was just completed in May 2019... This Judge retains all of its 100% original sheet metal, its original numbers-matching driveline, and all of the factory original documentation from day one..." You can be the judge on the colour https://forums.maxperformanceinc.com...4&d=1586127082 VIN 242371P110732 |
Really hate to seeing those 72 parking light bezels on there.
Beautiful car. |
What is incorrect on the bezel? It looks identical to my 71.
My 71 has the same grain - late June build.
Yeah, that dash grain is wrong. Should be the burled walnut grain like on the console. The seller acknowledged that the parking light bezels were from a 72 but left them on there as a personal preference, saying that they are easily removed.
I can’t see the PHS clearly enough to confirm, but the seller doesn’t list the Formula wheel in the list of options so I presume it was added. I did note that the hood tach was listed as a factory option. Looks like the restorer got it it right with the black paint in front of the glass gauge face, but I can’t see the defrost tube that runs over to the heather box. Were those on all hood tach cars? BJ |
I need to examine my old console, see if it is burl or grained.
Also will check to see if the bezel has a date code. |
That is a very nicely restored 71 Judge on eBay. Great pictures and details.
Mine is not close to the extent they went to in enhancing the restoration. https://uploads.tapatalk-cdn.com/202...10a69e3850.jpg Not sure about seatbelts on the eBay one. But, sure hard to get everything perfect as these are my original belts and upgrade are stainless. https://uploads.tapatalk-cdn.com/202...88866062dc.jpg https://uploads.tapatalk-cdn.com/202...5244e99859.jpg https://uploads.tapatalk-cdn.com/202...dfde032fb9.jpg I’m okay with mine being White. Nothing will be perfect... Sent from my iPad using Tapatalk |
Mike, I notice that you have the defogger hose with the white check valve in it that runs from your hood tach to the heater box. I wasn’t sure if those came on all hood tach cars or just those with the AC option. Can you shed some light on that and show a detail photo of where it connects on the fire wall?
BJ |
http://forums.maxperformanceinc.com/...1&d=1586321195 |
[QUOTE=Scarebird;6127643][COLOR="Navy"]I examined my bezel for a date code - none, just a part number. The applique is textured as shown, unlike the console applique which IIRC is aftermarket and may have replaced a bunged up Burl original. I bought the car in Fall of '96 and have no reason the think the dash has been out of the car before me.
Maybe someone else on here can shed some light on, if any 71 GTO’ s came with a dash insert that wasn’t Burl Wood. |
Scarebird, the 71 your talking about, is it a LeMans or a GTO? Only the 71 GTO’s had the Burl Wood grain. I noticed another post from you that your redoing a 71 LeMans.
GTO got burlwood on dash and auto console too. |
I do not think it was as clear cut as that. Here is a pic of a 1971 LeMans Sport with the Burl inserts. Both dash and consoles inserts look light colored so may not be original.
https://www.cars-on-line.com/photo/7...nt76222-10.jpg Ames catalog does not differentiate between Lemans/GTO/T37 as far as 1971 goes. only that is is different than 70 and 72. |
| All times are GMT -4. The time now is 02:45 PM. |
