1970 Ram Air IV Judge motor sittin' in the dirt
eBay ad for a 1970 ram Air IV motor sitting in the dirt in North Carolina. the ad says it has 614 heads and may even come with a 10 bolt rear end and transmission.
someone go check this out....https://www.ebay.com/itm/Limited-Edi...MAAOSwiuVeZtXZ |
RA IV motor in the dirt
here is the photo showing the motor and aluminum intake
Wonder what the block is??
Intake is aftermarket. Single plane plenum. I see nothing to suggest it’s a IV. if it is it’s probably for an auto as I see a flex plate on the back
Sent from my iPhone using Tapatalk |
Great way to store an engine!
8 bolt water pump & timing cover, as well :(
No pics of any identifying markings. No telling what it really is. I noticed that water pump also. Seems like every Pontiac engine 'came out of a Judge'....or at least a GTO.
If the 614 number is correct though...might be worth a look just for those. |
One pic does show it has at least one round port head.
:D |
Either been there for years or very soft ground. Gona need a back hoe lol.
Why is the photo of the side of the engine effectively cropped to omit the view of the cylinder head's exhaust area?
Seller has zero feedback.
The seller couldn't pull the motor out of the quick sand? Sheesh.
I would say the odds are really against the bidder on this.
Do you think it would really turn over? The heads would likely be the only thing of interest. What are the chances of the heads being better than powdered rust? For $2500 you'd be better off buying lottery tickets |
piss poor advertising and pics
but not as bad as the storage method . The clear plastic sheet covering deteriorated years ago |
Appears to have had a Moroso Vacu Pan system on it. Also has poly locks on rocker studs. Probably was someone's drag/bracket motor back in day. Normally would not install that system on a street car with mufflers. Also looks like an old Mallory Unilite distributor.
| All times are GMT -4. The time now is 08:16 PM. |
