-   73-77 A-body TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=439)
-   -   Odd question (https://forums.maxperformanceinc.com/forums/showthread.php?t=843034)
Flashflood 08-05-2020 04:18 PM
Odd question
What's the best way to find out if your time chain jumped a tooth without pulling the plate off. Or can it be done?
Sirrotica 08-05-2020 05:34 PM
If it only jumped one tooth it will run terrible because the cam is retarded. If it jumps more than one tooth it most likely will not start or run at all.
No sure way of telling other than remove the timing cover and checking the marks, that I'm aware of. You could remove the fuel pump to check and see how much slop there is in the chain. A Pontiac would have to have a lot of wear to jump a tooth with steel gears. If you happened to still have an engine with a nylon cam gear, it could jump easier if the teeth were falling of the sprocket. Pretty rare 50 years after they quit using nylon gears for one to survive though.
I replaced a nylon timing set, lying on my back in a driveway once. I was hurrying, and I accidentally got it off one tooth off, it barely ran. As many Pontiacs as I've worked on over the past 50 years, I can't remember any that just jumped over one tooth, the timing chain would have to be severely stretched for that to happen. Very uncommon in my experiences.
Now if you are talking Pontiacs with nylon cam gears (65-71, before 65 they used steel gears, and after 71 they reverted to steel cam gears) they jump when the teeth strip off, but they don't continue to run. You're dead in the water when this happens because the cam gear strips all the teeth off and usually doesn't turn at all. I've seen many many Pontiacs strip nylon cam gears, they stop running when it happens.
Flashflood 08-05-2020 11:24 PM
God I hate how I forget to do this but would Olds engines be the same way. I replaced the old chain and just finished putting it back together a couple months ago and it was a P.i.t.a so I would love it if I didn't have to do again
Sent from my SM-S111DL using Tapatalk
Sirrotica 08-05-2020 11:32 PM
Olds and Pontiac are similar, but not the same, neither is particularly tough to do. If you work at a decent pace 2-3 hours. Flat rate would pay maybe 1.5 hours start to finish.
You might buy a shop manual to give you step by step instructions if you're not familiar with Pontiac V8s.
