-   The Body Shop TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=417)
-   -   2K clear coat overspray on windshield (https://forums.maxperformanceinc.com/forums/showthread.php?t=845015)
dataway 10-19-2020 05:39 AM
What would be the best method/solvent etc. for removing 2k clearcoat overspray from a windshield.
Thanks.
73 TRANSAM 10-19-2020 08:54 AM
I would use lacquer paint thinner. This is what u use to clean your spray gun.
Tim66 10-19-2020 11:11 AM
overspray
You can use a razor blade first,and then go over it with the thinners.
ZeGermanHam 10-19-2020 12:19 PM
I'd probably take the approach of using lacquer thinner first to see how much will come off without a razor, then remove the more stubborn stuff with a razor, then do a final cleanup with another pass of lacquer thinner.
dataway 10-19-2020 12:23 PM
Thanks guys.
400 4spd. 10-19-2020 12:42 PM
NEW razor blade! After you try it dry, spray some glass cleaner on it and try it that way. Let me know which you prefer.
dataway 10-19-2020 02:12 PM
Luckily I have a pack of 100 new blades. Would imagine it would work better with the glass cleaner as lube ... raining right now, so it may be a day or so.
Greg Reid 10-20-2020 08:17 AM
Razor on face or razor on glass...I'm thinking either way some lube is a good thing!
62cat 10-20-2020 08:55 AM
000 steel wool. I use it on glass and brightwork.
RedDirtRoad 10-24-2020 06:21 AM
I prefer a Clay bar if it’s new glass
gary bennett 10-25-2020 05:47 PM
I use 0000 steel wool with lacquer thinner.
killakev 11-12-2020 09:19 PM
Where do you get this type of steel wool?
ZeGermanHam 11-12-2020 09:28 PM
Any hardware store, Home Depot, Lowes, etc.
dataway 11-13-2020 12:39 AM
I ended up using the razor blade method, worked great. This over spray was so light you couldn't see it except when the sun hit it at an angle, or at night. If I dragged the blade backwards you could hear a popping noise as it skipped over the dots of overspray .. then scrape forward in the area until the sound goes away.
In the past I've used the super fine steel wool also.
