-   All other Pontiac parts for sale/wanted (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=493)
-   -   #13 cylinder head (https://forums.maxperformanceinc.com/forums/showthread.php?t=847235)
feral cat 01-04-2021 10:23 AM
#13 cylinder head
date A160 casting only, cleaned, inspected $250 or bo loc ne pa
feral cat 12-14-2022 08:12 PM
cylinder heads
also have prs of # 13, #46, #62, #670 available
61DragCat! 12-22-2022 11:26 AM
Do you still have the A160 #13 head for sale?
bradleyc309 12-23-2022 09:48 AM
Would it be worth it or can you install #13 heads on a 1964 389 engine with Tri-Power?
61DragCat! 12-23-2022 07:18 PM
The 64 intake will not fit on #13 heads. And I believe the valve reliefs in the pistons are not correct for the#13 heads.
bradleyc309 12-27-2022 09:21 AM
I forgot to mention the Tri-Power Intake and Carb is 1965 model year.
b-man 12-27-2022 04:07 PM
This is a question that should be asked in one of the tech forums, I would suggest you try the Pontiac Street forum. This thread is in the classified forums and should not be used for technical discussions, out of respect for the seller who placed his ad here.
bradleyc309 12-27-2022 04:13 PM
61DragCat! 12-27-2022 06:39 PM
The 65 manifold will bolt to the #13 heads, but the 1964 piston valve reliefs will be wrong for the #13 heads. Are the engine block & the pistons 1964?
bradleyc309 12-28-2022 08:55 AM
The block is a virgin 11H code engine.
