467 numbers.
3 Attachment(s)
I thought I would share the results on the new engine for my 37. Overkill in a few areas but the goal was to make 500 hp and tons of usable torque. I think it has lots of room to grow if I decide at some point to put more cam in. The converter in the 700R4 is only about a 2200 stall. I'm pretty happy with the results!
1976 455 block Butler/Ross 467 stroker kit HR 230/236 @ .050 510/520 lift w 1.5 rockers 112 LS Butler Dport 87cc 310+cfm Edelbrock heads Warrior tunnel ram with 2 1407 Edelbrock 750 carbs Thorley 3 tube headers I'm retiring in about 5 months so planning on some road trips in the near future! |
Nice build- That’s gonna be a fun ride!
Congratulations man....badass gangsta ride you’ve made there!! Gonna be tons of fun!!
Should be a ton of fun. Looks great! Are those cymbals for air cleaner lids?
Sure looks like cymbals to me too...nice.
Nice street engine and I love the sleeper look. You're going to surprise a few people with that!
Nice build , but you have more power sitting there right now because your BSFC numbers are very much on the rich side.
You likely have another 20 peak hp and 12 more peak ft lbs of torque there ! |
Is that the engine dyno?
A very simple upgrade would to 4 tube headers. Great torque numbers for sure. |
Absolutely love the tunnel ram :thumbup:
Thanks! They are cymbals. The gas pedal is a early 40's Slingerland bass drum pedal.
That is the dyno sheet for that engine. four tube headers will come along in the near future. The tunnel ram works well on the street and the cool factor is way up there although I'm sure it's not the most efficient set up. All I was going to do was upgrade to a roller cam and then.......... |
Sweet build.
Stan |
Gotta say love the car , has a great look. The wheel overs add to the cool factor. Must say the tunnel ram is so neat ,don’t really see those used much any more.
Nice street engine and the OD is nice . What is the compression ? |
Lower compression on your build is fine . I’m only at 10:3 and have a much more radical combo and I’m happy there. Street car but gets to the track.
My son is a drummer and sent him the pics of the air cleaner tops. Loved it....... On a note congrats on future retirement... I’m a month away..... |
Nice. I have a similar build - still in pieces. I went with worked 7K3 heads having 230 CFM's, like camshaft, and the 800CFM AVS2 carbs. What is your compression as I seemed to have missed it? I am at a little over 9.0 but may mill my heads a bit just to get closer to 9.5.
2 Attachment(s)
Do you have the dyno numbers for idle on up? Was curious as to the HP/TQ numbers since the tunnel ram is often looked down on as a streetable piece at these lower RPM's. Again, most will say the tunnel ram is for mid-to-upper RPM's but from your dyno sheet, this does not seem to be the case. It seems to peak at a perfect RPM for a street engine. I am going more for the period look with my set-up, using velocity stacks topped with a Hilborn style scoop. Another thing I see. You have the finned valve covers. Make sure you have breathers. I see the oil fill cap, and assume a breather on the other side? I also have finned valve covers and will be using the Moon add-on breathers ala the old school look. I mocked them up on an engine I have sitting and will mount the breathers permanent when I have the tunnel ram in place on the engine. |
Tunnel rams are actually better than people give them credit for. The long runners produce good torque through the rpm range and they'll make hp. I've never seen an engine yet that didn't like a tunnel ram when setup properly.
2 biggest issues with them is packaging of course, and cold starts can be a pain, but if you're good at tuning the carbs you're using they can be made to drive pretty decent. Besides, nothing looks cooler on classic muscle than a period correct tunnel ram |
| All times are GMT -4. The time now is 05:43 AM. |
