Fun one for you guys
Where can I find these accelerator shaft/rod/linkage bushings?https://uploads.tapatalk-cdn.com/202...8e20d5de21.jpg
Sent from my iPhone using Tapatalk |
If you can't find the correct ones through our sponsor - Measure the ID & OD of what you need then try looking through MCMaster-Carr
https://www.mcmaster.com/bushings/bu...ture-grommets/ |
It's not clear from the photo, is it a soft rubber grommet or is it a harder plastic of some sort? Another couple possibilities are:
Try your local Ace Hardware store, they usually have a selection of grommets and bushings of various types in their hardware section. The companies that sell automotive weatherstrip usually have a selection of universal rubber parts that include various sizes of grommets. Try Steele Rubber, Metro Moulded Parts, etc. |
These may work. I always check “Chevy” listings for oddball stuff as sometimes it’s the same.
https://www.ebay.com/itm/31097884825....c101113.m2108 |
If you can’t find anything that works, I have a nice used set available.
| All times are GMT -4. The time now is 11:27 PM. |
