-   Members Helping Members (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=486)
-   -   TRAILER WIRING ? (https://forums.maxperformanceinc.com/forums/showthread.php?t=853742)
Old Goat Racer 10-06-2021 11:55 AM
TRAILER WIRING ?
3 Attachment(s)
I have a 1991 steel bed 18' trailer. I bought it brand new.
It sits in my shed all year with the mice. I took it out a couple months ago to tow my new tractor. And noticed the trailer lights not working. I found several chewed wires and repaired them.
ALL the lights are working properly, running, turn and stop and they are bright.
But when I hook it up tp my2017 Silverado I get a ding,ding,ding and a message on the dash "check trailer wiring" ding,ding,ding.
What's going on ?
dataway 10-06-2021 01:06 PM
If your truck has OEM trailer hookup it might be expecting to see brakes. There is also a different standard for plugs now I think .... something like seven wire vs six wire ... I forget.
"QUICK-SILVER" 10-06-2021 01:31 PM
Have you towed the trailer before with this truck and lights work?
My first clueless wild guess would be the trailer has standard brake/turn and the truck has seperate brake/turn.
Clay
67drake 10-06-2021 02:20 PM
I’m by no means an expert, but did have trailer light issues recently with my 2011 Silverado.
Did you check the fuses? I figured my trailer lights would simply run through the fuses for the trucks tail/brake lights, not so. The trailer wiring has its own fuses separate from the truck lights. I never knew that, and made an easy fix.
Joe's Garage 10-06-2021 04:43 PM
It's normally a ground issue.
From google:
Why does my truck keep saying check trailer wiring?
This condition is most likely caused by insufficient trailer grounding and the trailer ground wiring will need to be repaired and/or upgraded. 2. These concerns could be caused by a poor connection at the 7-way trailer connector. It could be either the truck and/or trailer side of the connector.
Several other sites pointed out chewed-on wiring causing the bad connection.
NHTSA says
NOTE: It is normal for the DIC to display "Check Trailer Wiring" when the trailer is disconnected from the truck while the ignition is in the run position. - Check Trailer Wiring message with DTC C1114 (NO Service Trailer Brake message). ... This symptom is caused by a short to power on circuit 47 or a poor trailer ground.
Good luck!
chuckies76ta 10-07-2021 08:07 AM
I had the same message on 2 newer 2021 GMC diesel trucks. Same trailer. Wire on brakes shorted to ground and I found blown fuse for trailer brakes on both trucks. Repaired wire installed new fuses everything ok.
Old Goat Racer 10-07-2021 12:03 PM
Clay
yes. Fuses all good, how else would all the lights work ?
I agree with the ground issue, gotta look.
Old Goat Racer 10-07-2021 03:09 PM
Ground is secure at the junction box but from there all wires go inside the box frame. 30 years mite be time to rewire the whole trailer ?
THANKS TO THE MOD WHO CORRECTED MY MISPELLED (WIREING). ;)
sdbob 10-07-2021 03:41 PM
When I built my open trailer 35 yrs ago I ran the wires through metal conduit. Left and right wiring separate till they junction at front. So mice can only get at wiring in the front.
