Trivia time
Each of these snowflakes was available on a different Pontiac. Which were they ? Which one is missing ?
There are actually 2 variations of the lower right in the lip edge. More trivia.
and many variations on color. How many know why there was a redbird but not a bluebird.
Who really cares? ;)
I have 8 WS6 in gold. |
Upper left looks like 13" FWD used on the Phoenix, upper right 13" RWD used on Astre & Sunbird's, Middle is 14X7 used on Firebirds? Bottom left 15X7 Used on F, G, B, & A bodies, and lower right is 15X8 used on WS6 equipped T/A's & Formula's. But I don't know what one is missing
Close: middle is 14x6 used on A, B, and G bodies. Pretty sure 15" was Firebird only and was available in most colors (natural, gold, red, blue,...) 13x6 on upper left is 5x100, right is 4x100. Rest are 5x120.7 (4 3/4). Thought there was a 5x127 (5") for big cars but could not find one.
Had 14x6 on front and 15x7 on rear of last Corvair. http://performanceresearch.us/padget.../snowflake.jpg |
And is the missing flake the 15x7 later variation used 79-81 f-bodys? |
What I suspect bird is referring to, is the 15 x 8 wheel. It has the deeper dish with a lip on the outside. There were a couple of manufacturers of that wheel, the webbing is a different size from wheel to wheel.
They never made a 5X5 bolt pattern Snowflake that I know of, one of the reasons I don't have them on my 78 Catalina Wagon.
Thought back in the day a friend had a set of 5x5s on a big wagon but was in the last century.. Have a couple of stacks that need sorting but mostly bought 15x8s for my Judge.
I thought I had seen these on a 2 door 80’s Bonneville once. It was black with a think a dark red vinyl top, red pinstripe and red interior. It had snowflakes on it but maybe the owner swapped axles/discs?
https://forums.maxperformanceinc.com...6&d=1503243886 |
There is also a snowflake that was 6" wide but still have 5x4 3/4 bolt pattern.
I have a set of these I wanted to use on my car trailer but I would have to change all the hubs and it is difficult to find hubs with that bolt pattern not to mention trailer brake parts like drums. |
Significant weight savings when compared to either the Honeycomb or the Rally II.
Pontiac also had aluminum rear drums on some of the late 70's (I think) Bonneville. Jon. |
I am not exactly sure what the criteria of 5X4.75 vs 5X5 wheel bolt pattern on the 77-81 Pontiac B-bodies. But yes all Wagons have 5X5, the couple of parts cars I have had with trailer towing packages (both 78 sedans) also have 5X5, but one had a Buick 350 and the other had a Pontiac 400 under the hood.
I did have a 301 powered 79 Catalina coupe that had 5X4.75 though |
I've had 2 WS6 TA's (1978's) so I like those rims and know the handling benefits. But for some reason, I also like the look of the 7 inch snowflakes on a TA, They showcase the snowflake pattern well.
