1968 Firebird 468cc 4-Speed - Priced to Sell FAST! $16,000 OBO
5 Attachment(s)
I have run into multiple family emergencies at the same time and need cash asap, as much as it kills me I have to sell my bird, I wish the pictures were better but this was a last minute thing and the weather outside is ugly.
I will also be listing on ebay, but I have really enjoyed the PY family and wanted to post here first. Please look closely at the pictures, the paint is driver quality and has some small chips as well as what looks like a carburetor fire burn spot on the hood. The interior is fully dynomat, new carpet, the console is for an automatic ( was an automatic car when I got it), front seats are aftermarket leather seats, only gauges that work are the water temp, oil pressure, tach, and shift light. Runs and drives great, sounds amazing. I have the PHS, car was originally Verdoro Green 350 AT. Please see the specs below, I will answer questions as quickly as possible. I do have videos / additional pictures available. Located in Fort Wayne, Indiana 46835 Price is $16,000 OBO Open to offers! My loss your gain, I need to move this as quick as possible. __________________________________________________ _______________________________ 1974 Iron Block Pontiac 400 - Bored and Stroked 468cc Balanced and Blueprinted by Kauffman Racing Equipment Ohio Crank Forged Keith Black Pistons 4.185 Bore Eagle Rods Zero Decked Block KP 400 4 Bolt Main Caps Crower Cam 60919 Comp Cams 1451-16 Magnum 1.5 Roller Tip Rockers Professional Products SFI Damper Billet Timing Chain KRE Aluminum 85cc Heads ARP Head Bolts MSD Pro-Billet Ready-To-Run Distributor MSD Blaster 2 Coil RobbMc 550HP Fuel Pump Cliff Ruggles built Quadrajet (17059201) Hedman Headers 3” Dual Exhaust Muncie M-21 Close-Ratio 4-SPD (‘68 GTO Purchased from Jim Mino) Hurst Competition Plus 4-Speed Shifter Lakewood SFI Blowproof Bellhousing McLeod Super Street Pro Clutch Kit PRW SFI Billet Steel Flywheel Southwest Speed Hydraulic Throw-out Bearing Moser Engineering Custom Built GM 12-Bolt Eaton Detroit Truetrac Differential US Gear- 3.73 Gear Set Moser 33 SP Axles Tubes Welded to Housing, Boxed-in Perches Wilwood Dynalite Front Disk Brakes 1” Drop Spindles Moog 1” Drop Coils BMR Fabrication Heavy Duty Boxed Subframe Connectors Calvert CalTracs Traction Bars Hotchkis Leaf Springs Rear Drum Brakes |
More Pictures
5 Attachment(s)
More pictures
Can you send me your phone number as soon as possible? 859-360-8421. Thanks. Or call me
Pm sent.
Are you in a position where you could deliver the car for some more 'bens'?
Google map says your 571 miles away. That's Fort Wayne to LaFayette, GA. Clay |
Sale Pending- I will update today.
Ok. I did all I could
Sold- Thanks PY!
Sold- Thanks PY!
| All times are GMT -4. The time now is 05:24 AM. |
