-   -   30 Amp fuse holder (https://forums.maxperformanceinc.com/forums/showthread.php?t=855544)
DANTIP 12-27-2021 03:01 PM
30 Amp fuse holder
2 Attachment(s)
My '72 Trans Am without A/C has the 30 amp fuse holder attached to an alternator wire. I thought that was for A/C cars only.
A few years ago Restore a Muscle Car sold a very similarly equipped original 4-speed T/A without A/C. Attached is a photo from the sale that clearly shows it too has the 30 amp fuse holder.
I hope someone can help determine why they were on these cars.
indymanjoe 12-27-2021 05:58 PM
I thought it was for the high speed in the fan/climate controll.
OG68 12-27-2021 06:06 PM
Electric grid rear window defogger?
giles 12-27-2021 07:49 PM
My 71 is a non-AC, blower defogger car with original engine harness and has a white 30 amp fuse holder. Ignore the black fuse holder in front of the valve cover. That’s a battery tender wired to the alternator + terminal.
Formulabruce 12-27-2021 07:51 PM
Not on a 10si..
This car has a ac engine harness probably. Look behind pass head for more unused wires
John V. 12-27-2021 11:25 PM
I learned about the 30A fuse holder on my '73 in this thread.
https://forums.maxperformanceinc.com...34#post6200434
I suspect it will answer your own question. There is a linked thread within it that may also provide answers. Mike (Held For Ransom) was a big help to me understanding it.
padgett 12-28-2021 12:19 AM
30A (white, twist top) is probably a standard harness and for the AC that is not there.
DANTIP 12-28-2021 10:34 AM
30A fuse holder
I've been working with American Autowire to figure this out. I learned from the '72 GM service manual that the "A" body harnesses contained the 30A fuse lead that exits the engine harness back near the TCS connector. However, the service manual schematic for the "F" body does not show the wire/fuse assembly. So, my non A/C 72 T/A did have the connector that exited the harness back by the TCS connector but was obviously never used (dirty and the plastic on the end of the connector looked a little melted).
BTW, my harness had a tag on it that read "0484" "RL". I strongly suspect the 0484 is the last 4 of the part number (perhaps 8910484??) and the RL would be a build sheet code. If anyone has more info on the "0484" part number or a build sheet that contains "RL", I'd like to learn more.
