-   67-69 Firebird TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=432)
-   -   is this a 69 reverse lockout (https://forums.maxperformanceinc.com/forums/showthread.php?t=857064)
Scott Thelander 03-04-2022 09:51 PM
I have this labeled as 69 Firebird with a Muncie can anyone verify for me thank you
Sport69 03-04-2022 11:39 PM
Looks like one to me. Can't read the tag, does it say for Firebird?
rwfisher 03-04-2022 11:45 PM
Appears correct.. Planning to sell?
Tellyshavilli 03-05-2022 12:33 AM
Try to look tomorrow
A Schab 03-05-2022 03:47 PM
No. That’s for a Auto. The Muncie swivel only has two bolts that hold it to the sub frame.
Scott Thelander 03-05-2022 04:42 PM
Hmmmmm
Must be 69 Camaro then
I had several 69 hurst shifters at one time in history
68 firebird 2.
69 firebird 2or3
69 small block Camaro
69 bb Camaro hurst complete linkage w mount plate
I will look more on line tonite too
Thanks gents
T
unruhjonny 03-05-2022 04:46 PM
if you can post the stamped (full or partial) numbers on those rods, I am sure someone can confirm it for you.
Scott Thelander 03-05-2022 05:53 PM
no stamping anywhere or on anything
yes I am going thru some f body stuff getting ready to
A Schab 03-05-2022 10:07 PM
The upper rod fits all Firebird and Camaro. The Muncie swivel is also shared with both cars.
Scott Thelander 03-05-2022 10:28 PM
https://forums.maxperformanceinc.com...d.php?t=702075
# 11 post
danm wish cammer was still around ,,,, his picture is exactly what I have .. exactly
A Schab 03-06-2022 01:01 AM
Scott,send me your e-mail and I will send you a picture. I don’t know how to post one on here. You could post it here for others then.
comanchefirebird 03-06-2022 08:50 AM
Hi Scott,
The pictures you initially posted look correct for a 69 Firebird with manual trans.
I have 4 of them here, all have provisions for 3 bolt screws to attach to the subframe.
Steve
Scott Thelander 03-06-2022 03:39 PM
Lockout id
5 Attachment(s)
Thanks to all that took time to post a message
To a small trivial item like this…
So
Here are a few more angles of my linkage,
My upper rod seems real straight less a soft bend
3.5” up from the adjuster some I have seen like the picture of my buddies has a bigger kink ,,,
My swivel is nearly flat looking down from the top long arm has a 1/4" offset to the frame side
I have seen a few with a good/bigger offset bend near the end for the linkage rods
Also looking from the side my swivel arms make a Y shape
Many I looked at have them at a 90 degree orientation making the rod holes farther apart
20” center to center. On long my long rod to the trans ... seems a saginaw would be shorter and 3 speed also
12.5 end to center on vertical column rod
What are yours??? When you have time
Scott
Scott Thelander 03-06-2022 03:48 PM
ID
So
A friend sent this picture of his original from his 69 RAIV TA. Just to liven up the discussion
His has 2 bolts and looks like his upper has a bigger bend farther up
The swivel looks a bit diff its brackets are at a 90 degree not a Y like mine ,,,,
And looks like I may have my rods in the wrong holes ????
comanchefirebird 03-06-2022 06:48 PM
Hi Scott,
I tried to crawl under the cars but cant get a useful pic
Attached is a pic of the 69 Service manual
This pic agrees with the layout of the reverse lockout on my two 69 4 speed cars (RAIII with M21 and RAIII w/M20)
Hope that helps,
Steve
Scott Thelander 03-06-2022 08:09 PM
Update
5 Attachment(s)
Thank you for the picture !!
I Just returned from getting my manuals and took a couple pictures also here’s a couple pictures of the linkage in a different direction similar to the manual thank you Steve as you stated and as the book shows it’s a Y On the idler leveler and my idler lever has the same shape and kinks as in the manual picture also has three mounting bolts the vertical lever to the column has a slight kink about 3 inches up and then straight just like mine and the reverse back Drive linkage rod has the same wiggles also so I think we’re getting really close with any of those 69‘s come with a two bolt support assembly just curious or the vertical steering column rod with a little bit bigger band in the middle thank you kindly don’t need to be touched up too much but just curious
unruhjonny 03-07-2022 10:21 AM
Scott;
Those two in the middle look like second gen Firebird three speed reverse rods.
https://forums.maxperformanceinc.com...9&d=1646612656
I had recently been sorting my own manual transmission shift linkage;
I was hoping to figure out if I had any correct second gen Firebird Muncie four speed linkage (which I do not).
turbo69bird 03-23-2022 03:07 PM
I’d be interested in knowing the build date on the cars . The 69RAIv w the two bolts and the 69 RAIII w the 3 bolts.
One of mine has 5290 on it and an S on the other side, this is not the bracket that bolts to the car (3 bolt by the way) but the part that swivels. Onto that piece .
A Schab 03-23-2022 03:13 PM
The IV car is 08 E.
turbo69bird 03-23-2022 09:39 PM
Believe mine is 03B
This pictured part is the part with the number and S on the back .
