Progression Ignition tunes
This can be the place to talk about Progression Distributor(s) and to share your ignition tables that work for you and your combination.
I just got my HEI setup and running and would love to see what others have done and would like to share. |
A lot of what can be done hinges on these details that you should post up about your car.
1) CID. 2) compression. 3) Cam. 4) rear gears. |
Very good point. My combo: 455/TH400, 9.2:1 compression, Comp xe268h cam, 3.08 rear.
I don’t have one yet but I may pick one up in the next month or two. I’ll be following this regardless
Can we add:
Carb) brand & size Intake) Look forward to the progression and the trends/differences with builds. Sent from my SM-G988U1 using Tapatalk |
461/9.7 static comp
6X4 approx. flow 250cfm 850 MD w/annular T2 w/1” tapered 4 hole spacer 700R4 w/lockup 3:42 Crower solid flat tappet approx. spec w/1.65: 244/252@50 0.525/0.551 112 LSA 91 Octane/ 0% ethanol After a lot of testing (still not done though) heres the best map so far with my combo. |
I edited my original post to add head info (keep it all together).
Thanks, my timing requirements changed dramatically when I switched from 6X to Kauffman D ports.
Has anyone used the Aggressive mode when creating a table? it seems to move all the timing numbers up quite a bit.
New guy here. My Progression distributor arrives Friday and I'm looking forward to putting it on. Been doing a lot of reading on timing for this car, just trying to come up with a base curve for starters. Here's my specs...
461 (original block) Eagle forged rotating assembly, balanced 9.75:1 compression (verified by builder) Original #12 heads, completely rebuilt but not ported or worked over heavily, screw in studs. Original iron intake XE284 cam. I know it's not well loved here, but my builder (Rick Johnson in Crete, IL) swears by it so I trusted him. I do run high ZDDP oil (Lucas Hot Rod). Quadrajet built to the engine specs (supposedly) 3.55 rear gear M20 no AC I can only get 91 octane here, so I've been mixing to get 93 or so. Would love to be able to run pump 91. Car currently makes about 9 inches of vacuum at idle. and likes about 20 degrees initial advance. I had to back that off to 16 due to hard starting. Yeah, that's an electric vacuum pump for the brakes. Any suggestions for a base curve , or some tips would be most welcome! Currently shooting for 20 initial and 34 total, all in at 3200rpm. I'll bring the total up and RPM down if it seems to tolerate that. Car seems to like to idle around 650-750, and I like the lumpy idle down there, so win win I guess. This is a street driven weekend fair weather car, will probably never see a track. It was a full rotisserie restoration so I just have too much money into it, and it's sentimental to my wife (her dad's car). |
Good luck..report back on the progress! |
Start retard capability is built into the Progression distributor. |
I would start off with 32 total in light of your 9.75 comp/ iron heads and the fast cylinder pressure rise of the 4.210" stroke.
I got my distributor installed this afternoon, started up, and sent a table. I think I've been consuming way too much internet and overthinking everything.
Given the details on my engine above, thoughts on this curve/map as a start? Idling at 800, but it doesn't just stay there rock steady, moves around within maybe 30rpm of 800 up and down or thereabouts. Unfortunately due to weather I can't take it out for a test drive right now but she seems to start up and idle nice. https://photos.app.goo.gl/BfjiidcdfuW46NVA6 |
Got my distributor installed, idle set, table created and sent. Thoughts on the below table for the build I listed above? It's idling at 800, not steady which I think I should expect due to the cam, but between maybe 770-820 or so.
Any advise or feedback is welcome. I can't take it for a test drive right now due to weather unfortunately. https://photos.app.goo.gl/BfjiidcdfuW46NVA6 |
Just ordered the HEI version of this. I'm wondering if I should talk to my engine builder about using it for break in and dyno pulls/tuning or just have him use my current dist and then I would install this myself. My concern is if he hasn't used one before is it going to complicate things for him vs just let him do his normal process?
I'd ask him; tell him what it is. If I were a builder I'd be pretty stoked to be able to input exactly what I want for a curve in, rather than dealing with weights and vacuum stuff. Plus I'd get to try out the tech for free. The interface is super easy. Or maybe he's old school and isn't interested, which is fine too.
| All times are GMT -4. The time now is 09:29 PM. |
