-   -   Drum to disc rear brake (https://forums.maxperformanceinc.com/forums/showthread.php?t=858140)
joes455 04-18-2022 10:10 PM
76 ta want to convert.Have moser axles with 10" ralley wheels lug eccentric.Looking for the brake shoes style e brake .Whats out there .all i have are the 80 trans am backing plates.Thanks joe
Scarebird 04-18-2022 11:23 PM
We have a setup - requires 15" rims:
http://scarebird.com/index.php?route...product_id=178
chevymad 04-19-2022 12:32 AM
I used trailblazer rears on my 74. Parking shoes in the hat and all. Somewhere on here is a guide to what you need.
Schurkey 04-19-2022 11:54 AM
Or hit the Treasure Yard, bolt on a pair of 11" drum assemblies, save a heap of money and eliminate a pile of headache.
joes455 04-19-2022 01:15 PM
Scarebird will the jimmy rotors fit 1/2 inch wheel studs?
Scarebird 04-19-2022 06:29 PM
yes, my T/A has 1/2" studs:
http://forums.maxperformanceinc.com/...1&d=1396747314
Half-Inch Stud 04-19-2022 06:48 PM
95-97 Lincoln Towncar has the mini-drum brake build into the Disc hub.
My GTO Dana60 did not do that. It has 79 T/A rear discs with 82-86 T/A calipers and brackets for old scool Emerge Brake apply. Geez been since 2006 and not needed any maintenance on the rear brakes.
67Fbird 04-20-2022 07:16 AM
just completed my S-10 swap...from 1981 oem 4 wheel disc. I did have to add 1/4" spaces to the backing plate to get the 4x4 rotos to line up centered in the abutment bracket. Other than that (minor mod to the spacers as the flange face actually has a locating pilot on it measuring 2.830" so 1 each spacer had to be "opened up" in order to fit flush)
Joe-Touring 04-20-2022 02:35 PM
If you have some coin burning a hole in your pocket, Kore3 makes a kit to adapt C5 Corvette parts:
http://www.kore3.com/proddetail.php?prod=10277-01
I bought the calipers from a junkyard, and the rotors/pads separately. Kore3 makes great stuff, the e brake setup is gorgeous. Tobin(the owner?) is also very helpful, I had no problem getting ahold of him over the phone.
joes455 04-20-2022 08:29 PM
I think I'll stay with the oem design.I have the oem bracket and oem calipers ill use as core for new ones @ 50.00 bucks a piece comes with springs
ta man 04-20-2022 08:30 PM
Nice parts! Now I know where to direct guys looking for rear brake parts!
76TA462 04-21-2022 12:00 AM
On my 76 TA I went to Wilwood for my disc conversion. Four piston calipers, 12.19” rotors. Part 140-7149DR. Had to pull the axles. And go larger than my 15 inch OEM wheels (Rally) but might not have had too. But happy I did for other reasons.
Scarebird 04-21-2022 12:18 AM
If you do that make sure to adjust/ratchet up the calipers E-brake first BEFORE bleeding. Also, every time you shut off the engine, engage the parking brake.
joes455 04-21-2022 11:26 AM
Scarebird your set up is starting to sound good.How much to 32025
Scarebird 04-21-2022 12:02 PM
They are $206 plus 22 shipping.
Note we are 3-5 weeks out like a lot of the industry.
