-   EFI Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=570)
-   -   holley terminator x (https://forums.maxperformanceinc.com/forums/showthread.php?t=858694)
mysticmissle 05-15-2022 07:39 AM
holley terminator x
Any guys running this in high hp applications yet? what pump? dual synch distributor is good, no crank trigger anymore?
what did holley change from the 565-107 to the 565-207
Formulajones 05-15-2022 09:14 AM
What exactly as far as higher HP applications?
Are you talking about the throttle body size and what holley says they are rated for?
I talked back and forth with Holley a few years ago and found the 650hp limiting factor for the 4150 stuff was the 4 smallish 100lbs per hour injectors. They came out with the terminator X shortly after with 4 120 pounders to fill the void, but already had an 8 injector 4150 Stealth unit that would do the job. After they wouldn't install 4 120 pounders in the stealth unit they tried to talk me into a Terminator X. I wanted a Stealth 4150.
I went against the grain and did the 8 injector 4150 stealth unit and showed they support the higher HP just fine. The car has already went 3 mph faster than it's ever been before when using the 4150 950HP carburator on an engine that made 724hp. So those 4150 Stealths certainly can support more power than Holley states, if you buy the 8 injector unit. No need for the fancy X or the 4500 style, unless that's just what you want.
Not sure how many people here can give an experienced opinion that go for the Terminator X with the 4 120 lbs injectors since there are very few people here that even push 500hp, and probably count on one hand anyone in the 600hp range. A standard Sniper would support any of that crowd.
mysticmissle 05-15-2022 04:14 PM
540 cubes 15;1
900 PLUS HP
Formulajones 05-15-2022 06:46 PM
I assume you run a 4500 style carb on that one?
JLMounce 05-16-2022 10:37 AM
The Terminator 4150 throttle body likely will not flow enough physical air for a 540 cubic inch engine. Typically without modification they flow in the 830 cfm range. You can get them to around 900cfm if you bevel the lower throttle bores, knife edge the butterflies and go to countersunk set screws on the butterfly shafts. I think you would be looking at the Sniper Stealth 4500.
There is also the new offering from FiTech that is making it's way to market, called the Nemesis. https://www.subscribepage.com/fitech-nemesis-pre-order
4500 flange, 1600hp capable and designed specifically for large cid engines.
https://www.enginelabs.com/news/sema...o-big-engines/
Formulajones 05-16-2022 11:03 AM
It's the 900+ horsepower that would have me looking at the 4500 flange.
I do know the 4150 can feed some decent HP and large CI engines, more so than Holley claims.
We were finally able to hit the track with the EFI on dad's car to show something I've been saying for months. Dad's 571 ci that dyno'd with a 4150 950HP carb that actually flows 870 cfm. It made 724 hp.
Best MPH with the carb was 124.
Now with the Sniper Stealth 4150 installed best MPH was 128. A big difference for something that is supposed to flow less than the 950HP we took off. I don't buy those Holley flow numbers on the EFI stuff considering the bores are bigger and the blades are bigger than the carb we pulled off, plus there are no boosters in the way. The MPH difference bears this out.
There were many other reasons we stuck with the 4150 on this application that are too long to explain, but it shows they do work on a decent HP application, as long as you have enough injector.
I do agree though, with 900 or more HP, I'd rather use a 4500, especially if you have already dyno'd the engine with a 4500 carb and have the intake for it.
XLR8STEVE 05-16-2022 02:18 PM
Putting this together with Term X stealth 4500. 8-100lb/hr injectors. 535CI tiger. Using the 535 lph Walbro in tank pump. Major difference between Terminator and Dominator computers are number of ins and outs. This has 4 ins and 4 outs you can program. I had a 1200PA from Fitech and i like the holley a lot better for how detailed the maps are. i think snipers are more like fitech. Easier to setup but not as tunable.
Haven't run it yet.
Formulajones 05-16-2022 02:50 PM
We run the 4150 Super Sniper Stealths with the 8 100 lbs. injectors.
The supers have extra inputs and outputs, I think 3 or 4, so they are basically set up electronically like the X and are fully tuneable with detailed maps.
I think as far as software goes, these Supers were the predecessor to the X platform with the only visual difference I've seen being the computer is in the Sniper unit rather than a seperate box.
mysticmissle 05-19-2022 07:02 AM
i have the components on the way holley 12-1800 pump, term x 550-1070, and msd 2384 distributor. ill up date in few weeks hopefully
Scott65 05-19-2022 09:42 AM
If you still run a timing chain, the crank trigger is worthwhile.
mysticmissle 06-12-2024 08:03 AM
So almost 2 years since ''making this investment" i finished installing the system yesterday. I have a friend who is pontiac and HOLLEY EFI knowledgeable and after about 4 hours of tuning we are ready to take it out of the garage and try and put a load on it in the upper rpm ranges, before going to the track hopefully in the next 2 weeks.
overall the install was pretty straight forward. I am suprised i needed to source and buy a couple sensors to make it run for what they charge they could include a IAT and fuel and oil psi sensors in my opinion. My start up went well, and it fired off rather quickly but i hadnt synched the distributor properly. So I had some phasing issues.
because this motor is large and the cam is larger much of his adjustments were in ranges he says he never uses on LS stuff. different animals obviously, but there is just no vacuum on a 278-286 solid roller for the ECU to use as reference. We had to build the tables, this was the apprehensive portion of the swap for me and why it took me two years to decide to install it. Good knowledgeable people make the swap easier, i have no doubt of their value in the swap. We are on race gas now, but E85 he feels will be easily scaleable from the condtructed tables.
THe motor sounds snappy and freer, as compared to the 1050 dominator i know was choking it off. The car on the tbrake sounds damn amazing.
HWYSTR455 06-13-2024 12:42 PM
Ok, just to clarify, the 'Terminator X', and 'Terminator X Max' are ECUs, and are replacing the HP and Dominator ECUs.
The difference between the 'Terminator X' and the Terminator X Max' is the same difference the HP and Dominator ECUs had, the Dominator & Max have trans control and a few other features.
The old 'Terminator' tbi offering was a tbi with an HP ECU with a sticker on it. This had 4x
80lbs injectors on it.
https://www.holley.com/products/fuel...4bbl_tbi_kits/
The 'Terminator X Stealth' is the Terminator X ECU with the Stealth tbi unit. They make them in 4x 80lbs (4150), 8x 100lbs (4150), and 8x 100lbs (4500). (Think they even had 4x 100lbs setups too)
Compare HP, Dominator, Terminator X, Terminator X Max, and Sniper EFI:
(Scroll down to chart/table)
https://www.holley.com/products/fuel...erminator_efi/
Compare Sniper Offerings - Sniper, Super Sniper, Sniper Stealth, Sniper XFlow, +++:
https://www.holley.com/products/fuel...on/sniper_efi/
I know it's confusing, but it evolved as Holley evolved and started snapping up other companies. I may have missed some or not got some of the stuff up there right, but the links are here, can look for yourself.
I didn't include 'legacy' stuff like Power Packs, Avenger, Accel DFI, Projection, or Quick Fuel stuff, but can see some of it here:
https://www.holley.com/products/fuel...on/legacy_efi/
HWYSTR455 06-13-2024 12:57 PM
what did Holley change from the 565-107 to the 565-207
Back to original questions:
Unless you have other restrictions, an in-tank pump using a properly baffled tank is best. The in-tank pump assemblies can support big power. There are even dual pump in-tank modules.
I would stay away from the dual sync if you can, a crank trigger and a mag or electronic distributor as a cam sync is a much better option. Try to use hall effect pickups, they are less prone to RF/EMI.
You can use a pro billet or a hyperspark dizzy as a cam sync. Holley owns MSD, and they are starting to make 'cam sync' dizzies, but don't think they offer a Pontiac one yet. You can get them with or without the 'spark distribution cap'. There's really nothing special about them, if you have a pro billet you can just use that.
https://www.holley.com/products/igni...tors/cam_sync/
You can even do CNP, COP, whatever, and go distributorless if you want.
Difference between the 107 & the 207 is the 207 is an updated 107 with coated internals for one, definitely use the 207 if you go the dual sync route.
RocktimusPryme 06-13-2024 01:54 PM
I dont have any experience with the dual sync, but I installed a hyperspark setup with my Terminator X and have been very happy with it.
There is one step beyond the directions you have to take for a hyperspark to Terminator, but there is information on it from EFISystemsPros. I recommend buying from them, their tech support is above and beyond.
R 70 Judge 06-14-2024 01:18 AM
Congrats on getting it up and running! I’d be curious to see your IAC settings with a cam that large. What rpm are you idling at?
mysticmissle 06-14-2024 07:42 AM
It's a stealth dominator set up
I will list screenshots when we get close there's too much black magic associated w this stuff if I can help someone get a running start on the set up I will
We aren't 100% sure the iac is working properly yet that is going to be the first thing we inspect
HWYSTR455 06-14-2024 07:48 AM
Many times, just like a carb, you need to crack the throttle plates some. You want the IAC to work at below @10%, adjusting the plates will get you there.
HWYSTR455 06-14-2024 07:49 AM
You have to do a TPS Autoset after adjusting the plates.
HWYSTR455 06-14-2024 07:53 AM
Start with the base calibration file 'TBI_Stealth_4150_8Inj_454ci' and go from there.
Since it's a Stealth, you don't need a cam sync, you can lockout a pro billet or use a hyperspark (hall effect).
https://www.holley.com/products/igni...arts/565-314BK
