-   61-66 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=428)
-   -   1962 Catalina 4 speed clutch setup (https://forums.maxperformanceinc.com/forums/showthread.php?t=858750)
Adecco 05-17-2022 05:05 PM
Looking for images or a a chiltons page to set-up my 1962 Catalina 4 speed, I believe I have all the needed things (clutch pedal intact) the z-bar and pivot ball..
I have searched and cannot seem to find anything.
Thanks Tom
tom s 05-17-2022 08:25 PM
61-62s dont use a pivot ball.It uses a shaft that linkage goes on and held with a C clip.63-64s use the pivot ball.FYI!63-64 WILL work on 61-62s and is WAY better.Tom
misterp266 05-17-2022 10:07 PM
...https://forums.maxperformanceinc.com...0&d=1652839594
Stuart 05-17-2022 10:08 PM
This is a picture from the 1961 parts manual, it should be the same for 1962. edit: MisterP beat me by a minute. :)
http://forums.maxperformanceinc.com/...2&d=1209130450
tom s 05-17-2022 10:28 PM
Thanks guy,the 61-62 part number 36 goes into a bushing in the bell.63-64 uses a screw-in ball that the Zbars goes over.Tom
Adecco 05-18-2022 09:36 AM
thanks guys this helps..
