-   Heating & Cooling TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=420)
-   -   Cold Case radiators (https://forums.maxperformanceinc.com/forums/showthread.php?t=858871)
JLuger 05-23-2022 12:57 PM
Cold Case radiators
Shout out to cold case radiators I put one in my 66 over the winter couldn’t be happier. Had it out a few times over the weekend temps 85-90 and I wasn’t easy on it.
68 Firebird 05-23-2022 05:09 PM
Cold case
Very happy with mine as well.
Running good stable temp.
Very well made.
Gerry
MidnightAuto 05-23-2022 09:59 PM
Me too. First thing I did on my car was to drop in the Antarctic package. Cold case rad, flowkooler clearanced, 160 tstat, clutch fan. Won’t get above 190 in 95 degree weather idling in traffic. Otherwise it’s 160 all day long.
nUcLeArEnVoY 05-25-2022 12:44 AM
Pretty much my exact setup, too, on my 1979 T/A, tho my clutch fan is heavy duty and I also used weatherstrip to seal the shroud to the rad. My needle struggles to even pass the first "peg" on the temp gauge (which is between 100 and 220, so 160)... after an hour drive, I can grip my hand around and just hold my upper radiator hose as long as I want without getting burned or hurt. May be running too cool now, tbh. Cold case, for the win.
And mind you, this was even with a massive exhaust restriction (found out recently that my heat riser valve was welded closed for some reason by a PO) - would explain the huge exhaust leak im still in the process of fixing as of a month now (broken bolts and I refuse to pull the head).
JLuger 05-25-2022 07:46 AM
I’m running a pretty mild 455 with a stock water pump with stock fan and clutch setup also sealed up the shroud. Good to go.
5th TA 05-25-2022 10:07 AM
In late 2020 I pulled the stock 301 out of my 1980 TA and replaced it with a Butler 461. The 301 had a small two core radiator, I replaced it with a cold Cold Case radiator and couldn’t be happier. I have a 180 degree thermostat and my EFI displays has never gone over 185, even in heavy slow moving traffic. I am running the stock 301 fan, clutch and shroud. I should mention I have not charged my AC yet, that will be the real test.
