LQ4 Build
I have an LQ4 at the machine shop for a 408 build. I had planned to run a 58 tooth reluctor wheel, which I didn't think would be an issue because I'll be using an aftermarket engine management, but now I'm wondering what else I'll need to make this work in a Gen III block? The LS world is new to me so any input would be helpful.
ls1tech.com
Yes, far deeper knowledge pool - here most are simply Stratostreak fans.
Leave the Gen 3 knock sensors and cam sensors in their stock position to plug holes. |
Thanks Marv. Next problem—what’s the best option for shaker? It’s going in a 79 TA…doesn’t need to be functional but I’d rather not attach it to the hood.
If you’re using the factory plastic intake and fuel rails you could make brackets off the rail mount bolt holes and set the shaker scoop up that way so it’s there for looks or run an Injected 4bbl intake with an accufab throttle body. If the engine mounts put the motor in the right spot too. Sent from my iPhone using Tapatalk |
Post an email and I will send the drawings for our old shaker air pan to LS1.
I am trying to educate myself with this LS stuff. Why are we trying to convert to the Gen IV stuff? Do you already have Gen IV engine management or something?
[email protected] |
sent.
The 408 long block is done. Ended up going with a 4.0" stroke Scat forged rotating assembly with 58 tooth reluctor wheel and a 230 240 114 LSA cam (.625 gross lift)...valve job and resurfaced the 317 heads. The engine will be going in my son's 79 TA so installed a Holley 302-3 oil pan.
Son has no interest in making the engine look old school, so that simplifies things. As for next steps, wondering if an OEM LS6 intake and cable operated throttle body would work well with this combination in the TA. Planning to use Terminator X. Car will have TKX, so no need for X Max unless someone convinces me to go with DBW throttle body. Not sure if the Drive Junky accessory drive will work...car has Ridetech suspension and True Turn. |
Is there “Half-an LS” 4 CYL ?
| All times are GMT -4. The time now is 04:03 PM. |
