Vintage Sun Engine Analyzer and Snap-On A/C Recovery machines
5 Attachment(s)
More results from my garage cleaning binge:
Two vintage (circa late 1970s and early 1980s) commercial A/C R-12 recovery units and a early 1980's Sun Performance Analyzer Model 1115. All three units include their original operating manuals. 1) Snap-On Model ACT 3000 R-12 A/C recovery system. Includes hoses, recovery tank (empty) and the operating manual. Unknown working condition. Very low hours on the meter - only used for 33 hours by the original mechanic before it was retired. $100 2) Auto Air Service Center Model 01016 A/C R-12 recovery system. Includes hoses, recovery tanks (empty) and the operating manual. Unknown working condition. $100 3) Sun Performance Analyzer Model 1115 with all manuals and attachments including timing light and emissions hoses. Everything but the exhaust emissions tester seemed to work the last time I used it which was several years ago. The exhaust emissions system needs the internal hoses replaced due to dry rottting. It was quite a lot of fun to play with, though. I was originally trained on this model monstrosity back in 1980 at Denver Auto and Diesel College. It even has the optional attachments to work on the new-fangled GM HEI system (which kind of dates this contraption to around the early 1980's or so. Has NJ inspection stickers from early 1980's. It is BIG: 6'2" tall and 3'3" wide. $100 Way too big to ship so local pickup in central NJ would be the only way to get them. (hence the low prices) Steve at [email protected] |
5 Attachment(s)
The Snap-On ACT3000 A/C recovery machine
5 Attachment(s)
Auto Air Service Center Model 01016 A/C recovery system
Does the Sun machine still work at all?
Yes it does! The only thing that doesn't work is the exhaust analyzer function since it uses a lot of what appeared to be latex or plastic tubing internally that dry rotted over the years. The oscilloscope worked well the last time I played with it, though I have forgotten what all the various patterns mean after all these years. Luckily all the original manuals have that info in them and go with the unit.
I used a very similar model 40 years ago. Two questions: Do you have the cable end for the HEI distributors? Also what part of NJ do you live in? I have to figure if the drive is worth it.
2 Attachment(s)
Yes, I have the adapter for the HEI. It's the white plastic rectangle pictured below the "SUN" labeled silver induction clamp. It takes the place of that clamp on HEI cars.
I actually tested it out on my HEI equipped '75 455 Firebird a while back. It was fun to watch the wavy lines on the screen. I'm in the middle of Jersey, around Bridgewater, close to where I-287 and I-78 meet. |
Thanks for the info. I would like the machine but it is just too far away. Good luck.
Thats is the problem with these things. It's like buying a refirgerator and having to move it to a new home! LOL
I had one but it took up space; infrequent use. Ignition scope works nicely to find bad plugs/wires. Nowadays I use a standard oscilloscope.
George |
In line for the Sun machine. PM sent.
I pm'd you back!
Sun Analyzer is sold! Thank you.
Now if anyone wants the Snap On AC rceovery units, come on down! |
| All times are GMT -4. The time now is 10:57 PM. |
