1963 lemans
3 Attachment(s)
For sale 30 K, Located in Wisconsin
IAII block 498 cu in 325 cfm Kauffman Heads 1.5 rocker arms Comp cam hydraulic roller Howards hydraulic roller lifters Northwind intake Holley sniper X-Flow EFI Hyper spark ignition Holley distributor 16 volt battery and alternator Ram air exhaust 2.5 in manifolds Pypes exhaust pipes and mufflers and stainless steel to the rear. Turbo 400 trans reverse valve body with JW bellhousing Precision of Hampton 3300 stall convertor B&M ratchet shifter Strange 4 wheel disc brakes Strange Ford 9" housing Moser Wave track center section with 350 gear 35 spline axles with 5/8 studs 12 gal fuel cell 15x9 billet specialty's street lites in rear with M&H drag radial 15x4 billet specialty's street lites in front with M&H (DOT) front runners Factory interior with power windows and removable steering wheel 850 cert cage (expired but should re-cert ) Stock front suspension with Calvert shocks Chassis engineering ladder bar, with anti roll and wish bone QA1 coil overs Heim joints with shoulder bolts . All steel car from Arizona in the late 80's Orion sliver is the color Possibly going to Norwalk 414 313 7860 Peter D. |
3 Attachment(s)
more pictures
BAD A$$ !!
Agreed
Tim john--- |
for those who have asked cam card
Very nice! You should have no problem selling this. Good luck with the sale.
Sold Thanks PY
| All times are GMT -4. The time now is 10:33 AM. |
