-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Planning turbo engine build (https://forums.maxperformanceinc.com/forums/showthread.php?t=860733)
quick67bird 08-11-2022 02:05 PM
I have some 32cc dish pistons in a 4.25 bore diameter that I want to use. I am planning on using these pistons. My thought is on what crank I would like to use. Should I use the offering from Molnar in a 4” stroke or should the 4.25” stroke. This is not some max effort engine, but should run good.
I have my 74cc combustion chamber aluminum Kre Dports for cylinder heads. With the 4” stroke I will get 454 cubic inches at about 9.04:1 compression. With the 4.25” stroke I will have 482 CI at about 9.54:1 compression. I have the turbo manifold already set up for a single turbo. I am thinking of using s S400 or an S480.
This is not a total budget build, but I do need to spend my money wisely to get it done.
charlie66 08-11-2022 02:46 PM
I'd go with the 4-in stroke. either stroke it'll be a really cool build. Good luck
AG 08-11-2022 03:11 PM
What's the CH of the pistons?
Tom Vaught 08-11-2022 04:07 PM
Travis Quillen told me some years ago, that he should have gone with a 4" stroke vs a 4.25 stroke
(482 cid in their 4.25 stroke Twin Turbo engine).
Tom V.
R 70 Judge 08-11-2022 06:03 PM
I’m currently gathering parts for my twin turbo build. After long discussions with very smart people who have been there and done that, I will be going with a 4” stroke. The extra load on the cylinder walls with a 4.25” stroke is not worth it. Don’t worry about the cubic inches, let the turbos make the power.
R 70 Judge 08-11-2022 06:10 PM
For a turbo recommendation try https://www.forcedperformance.shop/ and ask for Robert
This is a good video regarding journal bearings and ball bearing turbos
https://youtu.be/zEVEAnRdEF4
quick67bird 08-11-2022 06:48 PM
Thank you so much guys. I really appreciate your feedback about Travis Tom. He is an extremely smart guy. I will jump on Johnny’s amok at buy and hope we can get a deal going.
quick67bird 08-11-2022 06:49 PM
I will have to check AG. I bought them years ago and they are in my storage unit.
quick67bird 08-11-2022 06:52 PM
Thank you Charlie. I need to try and move this build forward.
Thank you for the videos R 70 Judge. I appreciate your feedback.
Tom Vaught 08-11-2022 07:50 PM
Smart enough that he is a "ROCKET MAN" for NASA these days vs a Pontiac Hot Rodder.
Tom V.
charlie66 08-11-2022 08:08 PM
Keep us posted. I hope you figure it out to your liking . Sounds like you have most of the stuff . Even if you used a 3.75 stroke it be killer...
Im using a 3.75 in the motor im building now .. I have no doubt it will have more power/torque then ill ever need..
quick67bird 08-11-2022 08:17 PM
Thank you Charlie. I have collected a few parts over the years. I just need the crank, aftermarket block, crank, turbo and figure out an induction system.
R 70 Judge 08-11-2022 09:05 PM
I’m using a Northwind with a Steve Morris billet elbow and a Wilson’s 105mm throttle body with Holley Terminator X EFI. I have thread going in the EFI tech section if you want to duplicate anything.
cgeise 08-15-2022 01:30 PM
I recommend you get the ring lands hard coated/ Anodized -- It will really help in the long run.
quick67bird 08-15-2022 09:34 PM
Curt is there someone local to us to do the anodizing or do the pistons need shipped off?
quick67bird 09-23-2022 06:52 PM
5 Attachment(s)
A few people asked to see my turbo manifolds that I bought a few years ago. I finally was able to make it out to my storage unit to get some pictures. Here they are if you all have any more questions let me know.
Tom Vaught 09-24-2022 01:26 PM
Hope they PACKAGE as good as they look in your vehicle.
Have fun. Tom V.
25stevem 09-24-2022 02:23 PM
If this is a factory block are you planing to fill it up to the bottom of the front timing cover water passages.
quick67bird 09-24-2022 05:41 PM
Have fun. Tom V.
I have mocked them up in my car and the turbo will sit real close to where the battery used to be in my Firebird. I will weld up a support to help support the turbo on the passenger front frame rail. I have been trying to do this build for a while. I start to get frustrated and think I will just sell everything. I just keep telling myself that the parts aren’t costing me anything sitting there. Thank you for your insight Tom.
quick67bird 09-24-2022 05:47 PM
Hey Steve the plan is to get an aftermarket block. I figure that would be the best way to go since I already have the dished pistons for a 4.25 bore.
