-   -   Glove box door arm-68 (https://forums.maxperformanceinc.com/forums/showthread.php?t=861946)
supersport#69 10-02-2022 10:12 AM
My door seems to sit too low I guess because the arm is grinding metal every time the door opens and closes. I can bend the arm but I’m wondering if I’m just missing something before doing that.
Anyone else have this issue? Could I be missing a spacer?
Greg Reid 10-02-2022 12:55 PM
I'm not sure what you mean by sitting too low but...Mine is centered in that opening so I think bending it would be my suggestion as long as the door itself is centered when it's closed. There is an L shape at the extreme end of that arm so you only want to bend it enough to clear the side, not so much that the L shape comes out of the hole.
Or are you meaning that it's grinding the BOTTOM of the rectangular opening? Yeah, that must be what you mean. Mine clears that just by 1/16 of an inch or so.
supersport#69 10-02-2022 01:27 PM
Oops, yes!
I meant the bottom is grinding.
supersport#69 10-02-2022 01:29 PM
I meant it is grinding at the bottom when open.
Greg Reid 10-02-2022 01:32 PM
Understand. Mine clears but just barely.. I think I would loosen the hinge bolts and see if I can get a little play out of it there first, try the bending only if that doesn't work.
Half-Inch Stud 10-02-2022 03:49 PM
Bend to center within dash slot, and be sure to have the rubber hose on the arm's end.
Scott Thelander 10-02-2022 05:57 PM
flat rubber hose on the end x 2
dataway 10-03-2022 03:03 AM
If you bend to center it WILL gain some clearance on the bottom. Think about it ... the farther over the arm leans, the closer to the bottom it gets.
You can also just crank the arm up a bit too, harder bend in that direction of course, but it will tweak ... you probably just need a hair.
