help starting my 66 lemans
Hi does anyone know of a mechanic in the south carolina area,myrtle beach to be exact.thank you for any help. Tim
What do you need done?
starting problems
I switched from mechanical to electric fuel pump.I also changed my starter and added a solenoid to the fenderwell.Also added a pressure switch and relay for the elect pump.Alot of wires,after two I get confused.Thank you
Tim |
Does it turn over or do anything?
help
yes,thank you,it does turn over,I'm going over fuel now.I'll let you know what happens once I get down to the car.
Tim |
Verify it has spark if you can.
| All times are GMT -4. The time now is 05:22 PM. |
