THM 400 vs THM 350 torque converter stall speed
Can a THM 350 torque converter be substituted for a THM 400 converter to slightly increase stall speed ?
Yes.
Not much difference in stall speeds, at least on the few I've switched. I think the bigger difference is the lighter rotating weight of the inch-smaller 350 converter. Really, not much difference at all. Consider getting a "real" converter. |
Yez, 2-speed or TH 350 converter are an advantage due to light weight, tightness and higher stall behind a 455.
How much rpm difference, 200 to 300 rpm ?
It all hinges on how much off idle torque your motor makes.
One thing I would sure as heck not due for long is place a stock TB 350 converter behind a good running 455, on less a strong running one. |
Yea, i don't know how or why but i suspect the ST-300 and TH350 converters may be weaker inside;
i suspect the Stator-sprag spline fit may be prone to strip-out due to exposure to extreme cold and hot cycles. Leading to pulverized aluminum bit trash in the fluid and a low stall pull away. |
A guy that worked for me, tried a Vega 350 convertor, in his GTO, really disappointing for street use. That's why I went with the full size 350, there was way too much slippage with the Vega convertor to suit me. Back in the day, the Vega 350 convertor was the poor mans high stall convertor. Car magazines were the source of the information, but it was poor information in my experience. |
By chance you ever run your 73 down the drag strip? |
I did however participate in a few impromptu acceleration contests on the public thoroughfares when the someone thought that their brand X was quicker than my Pontiac. I remember a SBC in a side piped corvette that got his ass handed to him, he was nice enough to acknowledge that my car ran well, after his loss.....:D In my experience, that's not your average corvette owner though. Background on the T/A, 455 HO heads, stock compression ratio, 8.2 to 1. Just a bone stock 455 block, and pistons. Hooker Competition Plus round port headers, and a 268 single pattern Comp Hi Energy cam, 1.65 rocker arms, a pretty mild engine. Factory transverse muffler and 2 1/4 pipes (not the best choice as far as restriction). As I already posted 3.08 axle, TH 400, with the 12 inch 350 convertor. Many of the Herb Adams low buck mods made to the chassis. L60 X 15 radials on the rear on American Racing 200S 15 X 8 wheels on the rear, G60 X 15 radials on the front, on the same American Racing wheels. Very well suited to spirited cruising, and occasional auto crossing. My signature black, with gold accents color combination, with a custom metalflake bird painted on the hood. Timeline, 1980. |
I just assumed that the 350 converters were essentially identical to the 400 converters except for the inch difference in diameter; in that some engine families got converters with flat brackets with a bolt hole, (Chevy) while some got welded-on oblong "nuts" that were threaded, to clear balance weights on the flexplate. Similarly, it seemed to me that some converters had roller thrust bearings while some had thrust washers. The thrust bearings might have been random, maybe a model-year change, maybe they were "big block" versus "small block", or maybe they were "Chevy" versus the more-expensive makes in the GM line-up. Never gave any thought at all to the guts of a 350 converter being weaker than a 400, aside from the thrust washers/thrust bearings. It'd be fun to spend a week at a converter specialty-shop, seeing how they do things and how the converters are built. |
I put a turbo 350 trans and a stock 350 converter behind a 502 Chevy crate engine. After five years of full throttle the converter deformed and the flex plate would rub the starter gear with any press of the throttle. I replaced it with a COAN 10" which has been trouble free. I dont think a stock Pontiac 400 motor would stress it too much, just want a little more converter from a stop without getting one with too much slip.
Stock TH350 with a factory converter.... the converter isn't the weak link. |
I think most every manual fly-clutch-pressure plate deal will be rotating more METAL mass than the big converters.
Quote ""...my 6-lug conv weighted 38 Lbs Half-fulla fluid"" Converter stalls and tightness: just figure that GM et al, does have a method to match converters to the vehicle weight, engine and gearing. Aftermarket Converter shops barely get that right. ECM must have found the real matching method because those ECM cars accelerate thru the mid-track like none others. |
I had a stock big car t400 with the bigger factory diameter converter (13”+)that stalled to 1600-1700 behind a 455. When we switched to a t350 stall the same engine pulled the stall to 2200. If you have the slightly smaller diameter converter(12”??) like was used in performance engines (Ram air GTO’s ect)with t400s that stall seems to be 1900-2000. Very little change from a t350 converter. The bolt pattern to the flywheel is smaller than the big converters..
Fun fact: my K-B switch-pitch with 1600/4000 stalls ran the same 1/4 mile ET and MPH in either setting or timed at the 60-foot.
So left it in low-stall for best grip. 469 CID into 2.54:1 and 3850 Lb. |
| All times are GMT -4. The time now is 10:11 PM. |
