-   Missing Pontiacs, Parts or Trailers (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=470)
-   -   '69 GTO RA (III) 4-SPD 4.33:1 Midnight Green w. dark Green interior (https://forums.maxperformanceinc.com/forums/showthread.php?t=864155)
K_McIntosh 01-21-2023 05:13 PM
Hey all ... I'm new here ... so, I am working on developing the VIN of my former (originally sold new in Canada) 1969 Pontiac GTO 400 RAM AIR (III) w. hood tachometer, M21 4-spd. close-ratio trans. & SAF-T-TR-HD 4.33:1 gears in Midnight Green w. dark Green interior that I owned & performed the 1st restoration of (original engine prof. rebuilt, original trans. prof. rebuilt, new Cragar wheels, new BFG T/A radial tires & a colour-match paint job) back in the fall of 1975 ... as a 19 year old ... I have yet to track down any paper records I may have retained at the time I sold the car in late 1976 or early 1977 for $2,800CAD (I'm quite sure I gave the new owner everything I had in the way of receipts & manuals ... I should have the ICBC APV9T transfer paper Seller's copy somewhere but I'll be damned if I can find it now ... 46 years later). If I can determine the VIN and what became of the car, I will gladly order VVS' (George Zapora tells me: "we [Canada] did not build GTO's here in 1969, they were imported") & PHS' documentation packages for it ... whether or not the car still survives, and, whether or not I can regain ownership of it again.
Aside from the car's primary attributes, described above, a sure to stand out modification I made was the sacrilegious act of cutting three 2" holes in the dashpad above the heater controls for three black-face Smiths gauges ... I also replaced whatever shifter knob came with the car with a black velvet-covered Hurst-style 'T' handle shifter.
FYI - the Canadian ordering dealer and month it was purchased, etc, may never have been known by me, as I purchased the car used.
So, I am fuzzy on stuff like a rally gauge pkg. in L dash pod (pretty sure none except fuel because I felt the need to add the three 2" Smiths gauges), clock in R dash pod (pretty sure no clock, definitely had a hood tach), center console (I think it had a console but am unsure now), F disc brakes (? ... the LF flex hydr. brake hose blew out on me one time ... you'd think I'd remember disc or drum brakes on the front but simply cannot), and, by extension, power brakes (I think it had power brakes), power steering (I think it had power steering), radio (I'm sure it had a radio but cannot recall if it was AM only, or, AM / FM) ... such is the state of affairs vis-a-vis my memory these days.
So, the big Q. is: has anyone out there run across my old car?
Thanks for reading all that, Kevin Mc
bdk1976 01-21-2023 06:04 PM
I would post this to the yenko site too as it seems like a 'special' enough car that it could be floating in those circles as well.
K_McIntosh 01-22-2023 01:43 AM
bdk1976 ... thanks for the tip ... I'll look into it in the a.m. ... K Mc
K_McIntosh 01-24-2023 09:03 PM
bdk1976 ... FYI ... that yenko site's new account (set in motion p.m. of 22nd) activation functionality must require human intervention and manual activation e-mail follow-through ... messaging the admin (a.m. 23rd) over there has not worked just yet either ... I'll just have to be patient for now ... K Mc
Pepper Judge 01-28-2023 01:15 PM
If you had the car registered in your name in Canada, (Ontario specifically) you may be able to work backwards from your driver's licence number to identify the VIN and then search from there.
Canadian documents for imported or made in Canada vehicles can be purchased through Vintage Vehicle Services Inc.
https://www.vintagevehicleservices.com/
1189 Colonel Sam Drive,
Oshawa, Ontario
L1H 8W8
George Zapora
[email protected]
K_McIntosh 01-28-2023 04:12 PM
Pepper Judge / George Zapora ... thank you for your post ... you and I have e-mail corresponded recently (my e-mail addy starts with my username here at PY Online) ...
I am in British Columbia and didn't get too far with ICBC (our mandatory government insurance provider and keeper of all things driver or vehicle-related since 1974) over the phone ... I'm going to write them a snail mail formal letter to see if I can get them to search their archived documents ... perhaps on microfilm or microfiche ... paper letters aren't as easy to shine on / ignore ...
I found a Judge / RAM AIR registry site for '69 GTO's that suggests my old car may have been a RAM AIR IV car under (last 7 char.'s) VIN 'P3204nn' ... I am in touch with Tim over there ... however, subsequently, on the registry's Pontiac MI plant sub-list, I don't find P3204 but do find two other cars where the upper & lower color are truncated to 'MIDNIGHT' ... so ... don't know if M. Green or M. Blue was meant ...
At any rate, I appreciate your help and suggestion George ... I'll write my letter to ICBC and try to sort out the 'P' sublist disrepancies with Tim.
Thanks again, Kevin Mc (K_McIntosh)
Pepper Judge 01-28-2023 08:12 PM
Good luck with the search Kevin.
In Ontario, you can have the Ministry of Transportation pull all VIN that have been registered in your name or run a search on the licence plate to get a VIN.
Not sure we emailed but maybe text messages?
K_McIntosh 01-30-2023 08:35 PM
Hey George ... thank you ... ON's system sounds better than what I have to deal with here in BC (ICBC).
And, we definitely e-mailed ... you e-mail Reply'd @ 0850E?ST Mon, 16JAN23, to my initial 2207PST 15JAN23 e-mail Send.
Kevin Mc
Pepper Judge 01-31-2023 08:52 PM
Wrong guy; no emails to or from BC, Jan 15 or 16.
Good luck with the search.
K_McIntosh 01-31-2023 09:25 PM
OK P J ... I mistakenly thought you had provided your outside world sig at the close of this post, above.
Kevin Mc
johnta1 02-01-2023 06:29 AM
Oshawa, Ontario
L1H 8W8
George Zapora
[email protected]
George Zapora is the guy who runs that company that was posted above.
They are like PHS is to the US Pontiacs.
K_McIntosh 02-02-2023 03:40 PM
yah johntal ... thanks ... I got that ... belatedly ... (George Zapora has heard from me twice now) ... as soon as I have figured out the VIN of my old (Canadian import) car, I will seek out George once again.
Kevin Mc
