Buffing windshield?
2 Attachment(s)
My recent purchase has been sitting outside for 25 years and the windshield has some grime or hard water spots on the outside. If you wipe it down wet it will be clear until it dries.
Recently tried this buffing compound on a spot. It did clear it up some but now it has a dull haze when looking through it. Maybe I overdid it? The picture is before buffing. I thought it might be between the layers of glass but it’s super clear when I wipe the outside down which gives me hope. Tried a little steel wool and various types of glass cleaner as well. Any suggestions? |
Cerium Oxide is used for polishing glass. I purchased it in the past from Eastwood but there are multiple sources available online
Tim john--- |
If it’s just grime and hard water, this is the best I know of that 100% won’t do any damage yet still give a perfect finish. Sprinkle it on a wet windshield and buff away.
BON AMI 1886 Formula - 12 oz (Pack of 2) https://a.co/d/i7wuure The original formula has no abrasives. Ace Hardware usually has it for under $2/can or can order it. If you’re actually buffing out scratches you need something stronger. |
Local "Detail Garage" here said to use a clay bar. My son did so on side glass for his 65 tempest which had the road haze. Came out great. used the clay bar lubricant as well.
Thanks for the replies guys. I did see cerium oxide when I first searching for the glass polish. I’ll have to give it and the clay bar a try. Hopefully I can report back with some good results!
Clay bar is good trick after polish dries. Toss it after, don't re use it.
Some of this on windows is actually mold.. |
I've used CLR (calcium lime rust) in a spray bottle and some fine steel wool. The "hard water" spots are usually calcium carbonate. We have BAD hard water around here.
| All times are GMT -4. The time now is 12:52 PM. |
