-   -   VIN vs Cowl Tag mismatch (https://forums.maxperformanceinc.com/forums/showthread.php?t=865291)
JEC3039 03-17-2023 01:27 PM
I'm looking at a '68 Firebird that has a dashboard VIN of 223378Nxxxxxx and a cowl tag of 68-22437 LOR.
How can a car be built in both Lordstown and Norwood at the same time? Seems fishy.
Anyone encounter this before?
JEC3039 03-17-2023 01:33 PM
Whoops. It's not an N in the VIN, it's a U, which was Lordstown, so that's ok.
Still leaves the mismatch between 22337 and 22437.
unruhjonny 03-17-2023 02:33 PM
the cowl tag will often have the characters of a base model, and the model RPO code will be a couple lines down.
as an example a 1970 Trans Am would have a cowl tag stamping of 22387 (base model Firebird), then two lines below would be the RPO code WS4 - which indicates it was a Trans Am.
I think it was done this way because the cars all started as base models, and as they went down the line became associated with a specific order number.
TedRamAirII 03-19-2023 10:25 AM
As long as the partial VIN on the Cowl matches the VIN, I would not worry about it. You may be able to see it, without pulling the cowl panel off.
