1972 restomod Trans Am done right on BaT
https://bringatrailer.com/listing/19...omments-anchor
Such a nice build. Must be a blast to drive. Almost all the right mods. All I would do is rip out that 10 bolt, and those stock leaf springs, and put in a 4 link with a 12 bolt. Then it would be ideal. |
Very nice!
wow...
I love this car!
This BAT car description sure knows what words to drop. That said It does NOT have a Gardner Exhaust system. This car looks like one built at 11:1 for e-85 fuel only a few years back..
This is why GM didn't add those wheels till STRUTS were in the cars. |
Beautiful TA.
Curious what the 'official' definition for a restomod is? Drivetrain swap? Suspension/tire mods? Anything not original? For instance, my 70 GTO has original drivetrain (engine/trans/rear end (added LSD)), but tubular control arms, 4 disc conversion (was front disc/rear drum) with hydroboost, quick ratio steering box, coilovers, 18" wheels, DUI, LEDs. I consider it a restomod with original drivetrain. |
I'm thankful it does NOT have a LS engine....
I LIKE IT!.....a lot
The LS engine is the BEST engine GM has ever produced, and GM is the same company that produced the Pontiac engines. It is worthy of being installed in ANY car, and will be an improvement over whatever was originally installed. Just quit with your efforts to disgrace those of us who have installed LS engines in one or two of our cars. Tell you what, if you have an LS engine that you would like to trade, I have a P400, a P455, and a P350 that I'll trade you head up. You don't like LS engines in Pontiacs, GOT IT! But some of us do. It ain't 1972 anymore. |
^^^ what he said.
A 1967-74 Stratostreak scales in around 660 IIRC, the LS3 in my T/A just under 400 - huge difference in handling; agile versus plowing thru corners. The battery being relocated to the right trunk makes this even more so. |
While anyone can do whatever they want to their car, if one loves an LS (errr...small block chebby) so much why not just buy a bew caddy, vette, or camaro and call it a day.
I much prefer seeing and and would only ever have a traditional Pontiac engine pushed to it's limit in a vintage Pontiac. And before someone uses the weight against a traditional Pontiac engine, well, you can get a new aluminum IAII or MR1A block. Putting an LS is a vintage car looks wrong and the car loses it's soul. And in most cases, torque - which is what makes a Pontiac a Pontiac. |
Oh God, not this again. |
Nothing cool or good about restomod BS.
I own a 2004 GTO that I bought new in June of 2004. It currently has 108k miles and only THREE bolts on this engine have ever been loosened. The two that hold the thermostat and the oil drain plug, that's it. I,m not advocating that everybody should replace their Pontiac engine with an LS. But quit with the efforts to shame others who choose differently. It is not an irreversible move and one could always switch back. But the car itself is what we truly love and in my opinion, the LS only makes it more enjoyable the same way aftermarket suspension and brake components make it safer. Also, as beautiful as the BAT car is, I personally would take a different approach. But the only reason I even replied in this thread is because a certain poster constantly reminds us of his disdain for non-Pontiac engines in Pontiacs. I respect his right to feel that way, but it is tiresome. |
| All times are GMT -4. The time now is 05:00 AM. |
