-   67-69 Firebird TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=432)
-   -   1969 Pontiac Firebird "Short Issue" When pulling out the headlight switch (https://forums.maxperformanceinc.com/forums/showthread.php?t=866592)
64Lemans 05-12-2023 07:50 PM
Hello.
I am in the process of replacing my headlight switch due to the issue I was having with my front parking lamps.
As you know to do this, I had to pull out the dash to get to the headlight switch.
I have since replaced the switch, but now every time I pull the headlight knob out to turn on the light, the front headlights, gauge, shift indicator light, etc.. the interior lights (shift indicator light, gauge lights) will turn on for a sec and then goes off as the headlights will remain on. So just the interior lights go out.
The 20 Amp fuse that is labeled "Tail"...blows everytime. I haven't touched or changed any wires. I also put in the old headlight switch and the problem still occurs. This problem also occurs with or without the gauge cluster attached.
I can post some pics of the wiring if needed. Any ideas, please let me know. Thank you.
Goatracer1 05-12-2023 10:40 PM
If you didn't have this problem before disassembling the dash check that you didn't damage any of the wires . If nothing is found then it must be an independent problem and you are going to have to check the wiring to the rear lights.
Sport69 05-13-2023 07:51 AM
Sounds like a grounding issue, maybe you pinched a wire somewhere, very easy to do.
64Lemans 05-22-2023 09:49 PM
Update **
I now have the parking lamps working correctly. Had to switch a couple of wires around. The correct filament is on for the parking lights. The directional is working on both sides as well. :)
My last issue is... The running light on the passenger side works and stays powered. No issues..... But on the driver side, the running light is not working. I have tested the socket and bulb, both of which are fine. I'm sure its a wiring issue of some sort but I'm confused as to why everything else is working just fine. (lamps, directionals etc..) I will check the wiring diagram but in the meantime, if anybody has any ideas or suggestions..on what to check, I would greatly appreciate it.
